Cheep air framing nailers
Discussion in 'The Tool Shed' started by bigjbear, Apr 11, 2006.
  1. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    Well the big storms came through Atlanta the other day and knocked down part of the privacy fence. It is mounted to my deck so it tore that up, too. It is going to a b!tch to to get it lined up and nailed back into place, so I'm thinking this is a good time to buy a new tool. I was looking a these from HF: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=46240 Seemed like the best one. But there are these two also: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=4041 or http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=91054
    Opinions please. I do not do construction work and this will not get much use, but I don't want it to fall appart before I finish. A friend of mine has one that looks like the first one, but he moved to TN and I need to get this fixed in the next day or two. His worked fine, but he didn't use it much either. $150 is what I'm thinking is the most I will spend (of course I'd rather spend less). I checked the local pawn shops today and everything looked beat. So its probably going tobe HF or Northern.
  2. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
  3. bigjbear
    Feb 18, 2000
    13,964
    447
    Marietta GA
    going shopping in 30 min-any comments?
  4. K5Kell
    K5Kell Guest
    Dont know if you allready purchased, but I would recommend picking up a Senco or something like that from a pawn shop as long as they let you make sure it works. They usually only go bad when the seals blow out. Usually the construction tools that go through the pawnshops are some of the best because unfortunately they are all pretty much stolen of jobsites, out of work trucks... hence the paint on them(owners mark).
    -Kell-
  5. greywolf
    greywolf 1/2 ton status
    Oct 18, 2001
    1,606
    ST.PAUL TX USA
    pasload cordless!baught it doing katrina clean up and love it butttttt its 3x more then what those are:crazy: pawn shops are your friend(sometimes)
