Chemical Stripping of Rust?
Discussion in 'The Body Shop' started by skratch, May 28, 2004.
  1. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    Does anyone know what I can use to chemicaly strip rust off of metal parts on my rig.
    I don't have access to a sandblaster for these smaller parts but I need to get them clean enough to paint.
    The wire wheel is getting old doing all these parts (knuckles, hubs, transfercase adapters. . .)
  2. devilsquid
    devilsquid Registered Member
    Apr 22, 2004
    91
    Groton, CT
    According to the back of the bottle, /forums/images/graemlins/deal.gif you could soak them in Metal Prep from POR-15. I've never tried to though so I don't know if it will actually work. /forums/images/graemlins/dunno.gif
  3. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    I was just reading in 4x4 Builder of a product called Evapo-Rust . It's a water based product that removes rust. I'm going to research it and see if it's as good as they claim.
  4. skratch
    Oct 28, 2003
    1,646
    Gorveport, OH
    OK, I guess a better question would be; What do machine shops use when they hot tank an engine.
    That would get these parts clean enough for what I want to do to them.
    A sandblaster would be better but that's out of my budget right now (so's the air compressor that's required) /forums/images/graemlins/whistling.gif
  5. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    One of the easiest methods I've found for stripping rust uses lye, water and a battery charger. It goes like this... take a plastic container like a 5 gal bucket. fill it with water and add lye (red devil drain cleaner or similar product) about 1 tbls per gal. Stir well. take the rusty part, degrease it, wrap it a couple of times with wechanics wire and put it in the solution leaving a "tail" of wire sticking up above the liquid. Take a clean bare steel rod, rebar is good, and place that into the bucket NOT TOUCHING the rusty part. Now hook a battery charger up to the two parts, negative on the rusty part,(I think, been a while since I've done this)positive to the clean steel and plug it in. If I've remembered the polarity the rusty part should start to bubble and fizz gently after ten minutes or so. Let this cook for 24 hours. When done, the part should be removed, scrubbed with a bristle brush and hosed off. Most of the rust should be in the bucket, the rest should wash off. Second treatments are rarely needed. I've done anything that'll fit in a 5 gal pail, 16.5" wheels in a 16gal shop vac base, tierods in a length of 4" pvc pipe capped at one end. Obviously large stuff like diff housings and entire frames can't be done this way. I did the ends of my d60 by standing it on end in the 5gal bucket /forums/images/graemlins/yikes.gif I don't recommend this, thats a heavy sucker. Give this method a try on small stuff, then get creative. The solution can be freshened with lye a few times. I dumped the used stuff down the toilet where the drain cleaner would go eventually.
    RobTav63 likes this.
  6. skratch
    Oct 28, 2003
    1,646
    Gorveport, OH
    SWEEEEEEEEEET!
    I'm gonna get some stuff tomorrow and try this out.
    Thanks a ton!
  7. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    you forgot to add, MAKE SURE YOU WEAR GLOVES.
  8. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    More so than that, EYE PROTECTION.
    A little bit of LYE in 5 gallons of water will most likely not cause irrepairable skin effects (but why suffer?). However, your eyes arent nearly as forgiving.
  9. WyoSquareMan
    WyoSquareMan Blood type: GM Premium Member
    Nov 2, 2014
    292
    60
    Gillette, Wyoming
    I realize that this thread is like 12years old but muratic acid works friggin awesome you can soak or just use a brush, just make damn sure you DO NOT GET IT ON ALUMINUM!!!!! and it's water slouable just rinse really good with the garden hose
  10. skunked
    skunked in the garage Premium Member GMOTM Winner
    Feb 27, 2013
    6,504
    3,573
    Placer County CA
    That's some nasty stuff. I use evaporust, cost more but it doesn't irritate the skin and is biodegradable.
  11. WyoSquareMan
    Nov 2, 2014
    292
    60
    Gillette, Wyoming
    Where do you buy it?
  12. Chief Brody
    Chief Brody Chief of Amity Police Premium Member GMOTM Winner
    May 18, 2010
    7,636
    297
    Alabama
    I know you aren't going to believe me, but if you have the time, one of the best rust removers is molasses. It's cheaper ifyou get feed grade at the Co-Op but if you soak parts in molasses for one to two weeks, it will completely remove the rust without removing material. It's astonishing! I know it works because I used it on my vent windows...removed the rust without scratching up the chrome. Took two weeks in a 55 gallon drum of molasses
  13. skunked
    Feb 27, 2013
    6,504
    3,573
    Placer County CA
    Harbor Freight however some other hardware stores sell it too.
  14. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,030
    1,347
    Kzoo, Mi
    I've used it on nuts/bolts....works pretty good, is reusable, water cleanup, safe on the hands and eyes as well.
    I got it on Amazon.
    check it out
    HERE
  15. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    Plain white vinegar works remarkably well on parts small enough to be submerged in it also...its fairly cheap in bulk too...
    I filled the rusted master cylinder on my van with vinegar after it had sat empty for years and rusted badly--it took a few days,but after I removed the vinegar with a shop vac,it looked like I had sandblasted the cast iron,it was nice gray color and clean...but I ended up deciding for 20 bucks I'd be better off replacing it..wasn't sure if it harmed the piston seals,but it did seem to work fine--pedal was "stuck" before I soaked the master with vinegar..
    The electrolosis tank works best out of them all probably..same method they use to restore shipwreck parts and treasure !..
  16. BlazerRico
    BlazerRico Registered Member Premium Member
    Mar 8, 2016
    11
    You don't need to use lye for the electrochemical removal, washing soda will work and it is less caustic. You want Arm & Hammer washing soda from the laundry section.
  17. JoshHefnerX
    JoshHefnerX 1/2 ton status Premium Member
    Jan 7, 2015
    1,816
    828
    Glendale, AZ
    Evapo rust is used by NASA and the military. Soak it and rinse under water.
  18. RobTav63
    RobTav63 1/2 ton status Premium Member
    Aug 23, 2014
    209
    112
    Yaphank, NY
    my GF is in archeology and this is what they do, it's pretty amazing when you see the results. I've submerged wrenches with white vinegar and was happy with it
