Chev 10bolt suggestions
Discussion in 'The Garage' started by KnighTs-T, Apr 17, 2002.
  1. KnighTs-T
    KnighTs-T Newbie
    Apr 17, 2002
    I am about to replace bearing thru out front end...along with hubs..... i was planning on using timken bearings? any suggestions.... and also using premium hubs from warn? any other ideas...anyone has while i have this diff tore apart?
  2. Overkill
    Overkill 1/2 ton status
    Jan 15, 2002
    284
    Orlando, Florida
    Sounds like a good start. Use marine grease throughout and you should be good to go. marine grease repels water better.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Change the axle ujoints in the front axleshafts.
  4. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    timken makes good bearings...a lot of companies use their bearings for install kits
    Later
  5. White Knight
    White Knight 1/2 ton status
    889
    Ft Worth,Texas
    Just a thought.....use the 10 bolt for a door stop and shove a D60 in instead......LOL while you're there do your brakes and extend the breather tube up as high as possiible. If you have the cross over tube with hollow ends...dump it and get a thick solid one.
    White Knight
  6. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I would use synthetic grease, 3x's as much but definately an advantage over regular or Marine grease.
  7. KnighTs-T
    KnighTs-T Newbie
    Apr 17, 2002
    thx guys
