chev outers ford bearings and rotors
Discussion in 'The Garage' started by cad500, Oct 3, 2006.
  1. cad500
    cad500 Newbie
    Oct 3, 2006
    oakridge oregon
    hi gang.i'am new here and have a big question.i have a 1947 willys 2 wheel drive pickup that has a 9in ford rear and a 1974 scout 11 dana 2 wheel drive front straight axle. i want to go chevy 10 bolt knuckles out but use ford bearings and rotor on the chevy 10 bolt spindles.can i use ford bearings and rotors on the 10 bolt spindles.the jeep guys do it with the dana 44 knuckle out spindle and use the ford stuff so they can have the fords 5 on 5 1/2 bolt pattern. to match the 9in bolt pattern.i also have a 1960 willys wagon 4x4 with all 3/4 ton chev drivetrain.1975 corp 14 bolt rear and dana 44 front.i love the chevy suburbans but the ones i can afford are rotted out hulks.any help will be much appreciated thanks
  2. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    you need to get the early dana 44 small bearing spindles from 73-76 aprox to use. the 10 bolt ones are almost always big bearing spindles.
