Chevrolet Dana 44 HD ready to run
Discussion in 'General Parts for Sale' started by eripley, Oct 9, 2006.
  1. eripley
    eripley 1/2 ton status
    Oct 1, 2003
    145
    knoxville,tennessee
    Chevrolet Dana 44 HD Heavy Duty version
    Flattop knuckles both milled, drilled and taped.
    CC machine made histeer arms with long studs, cone washers and 1 inch spacers already installed.
    HIsteer Steering arms tapered to accept chevy drag link ends.
    Tie rod with new ends included.
    DOM threaded draglink with new ends included.
    pitman arm that fits chevy 2x4 box and already tapered for DRE/TRE.
    Spring plates and large ubolts.
    New bearings and seals.
    Welded spiders not carrier. if you dont want it locked just replace spiders or install any spool based locker.
    Drive flanges.
    New MOOG balljoints.
    New calipers, breakpads and rotors!
    Heavy duty front calipers.
    4.10 gears.
    70.5 wms.
    8 lug.
    Only has three trips on it.
    Everything you need to bolt and go. Just attached springs and install included steering arm and put on tires and its good to go.
    $650 OBO
    i tried to take the best shots of it ...its off the truck but as soon as I removed it and get a chance I can take better shots.
    http://www.bionpc.com/pictures/dsc08166.jpg
    http://www.bionpc.com/pictures/dsc08167.jpg
    http://www.bionpc.com/pictures/dsc08168.jpg
    local pickup only.
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    would you be willing to part out?
  3. eripley
    Oct 1, 2003
    145
    knoxville,tennessee
    I'll consider it after I have tried everything in my power to let it go as a whole.
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    ok let me know when you decide i am intrested in a few things off it
  5. eripley
    Oct 1, 2003
    145
    knoxville,tennessee
    Here are my prices parting it out.
    4:10 gears pinion carrier ring gear welded $40
    axles inner and outter both sides $90 or $45 a side with new ujoints.
    bare HD housing $50
    2 flattop knuckles with brand new moog balljoints drilled milled and tapped $180
    http://cgi.ebay.com/ebaymotors/Dana...3QQihZ007QQcategoryZ42609QQrdZ1QQcmdZViewItem
    2 1" steering arm spacers for histeer
    2 steering arms for histeer reamed for tie rod ends
    6 long studs and cone washers and nuts all for $150 http://cgi.ebay.com/ebaymotors/Dana...011QQitemZ320034973998QQrdZ1QQsspagenameZWDVW (this is the kit I have)
    1 yj drop steering arm reamed for tie rod ends
    1 1.25 inch thick .225 dom tubing draglink 40 inches long with brand new tie rod ends all for $100
    1 stock tierod with new ends $20
    spindles $20
    wheel bearings and races and nuts $20
    new brake calipers left and right $40
    New rotors left and right $40
    Dana 44 cover and bolts $15
