Chevrolet Oil Filter Bypass Relief Valve Plug
Discussion in 'The Garage' started by rcamacho, Jun 20, 2005.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
  2. jasonkh2tg
    jasonkh2tg 1/2 ton status
    Mar 27, 2003
    139
    MPLS MN
    bypass
    The filter bypass is there for a reason one for the driver who neglets the vehical and the filter becomes clogged...or if for some unforseen reason the filter became clogged the oil would still flow....I wouldin't go with a oil filter adapter with out a bypass unless it was a all out race vehical...If your filter is in good working order and changed on regural intervals there won't be any oil going through the bypass....the bypass is there for a reason to protect your engine in a filter failure....
  3. dyeager535
    26,982
    190
    From what my dad sees racing, about 30 laps and for whatever reason, the filter needs replacing with no bypass. These are Napa (Wix) Gold filters too.
    Oil pressure drops much quicker vs. running "bypassed".
    It must not be too big of a problem, (stock bypass) engines typically run 100,000+ miles with that setup.
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Bypass blocking is a bad idea- Your engine needs to go into bypass in things like the cold mornings, etc, when it needs oil, but is too thick to pump through. if you remove this function, you will damage something.
    If you want better filtration, add a bypass filter system.
  5. rcamacho
    Jul 1, 2004
    1,324
    WA
  6. 74huggerorange
    74huggerorange Registered Member
    Apr 7, 2003
    61
    Tulsa, OK
    I run a remote mount oil filter that has no bypass and have since 2003. I run a wix filter for a 74 chevy luv (dont ask me it just fits) and the wix book says that this filter has no bypass. I have put a bunch of miles on the truck and the motor is still doing great. I have even torn it down after 25k miles (3 years) to swap cams and everything looked a-OK.
