Chevron Delo
Discussion in 'The Garage' started by onlychevy6, Nov 14, 2005.
  1. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    How many of you run the chevron delo diesel oil in your gas rigs? I was turned on to this and was surprised it actually works.:eek1:
    Was told it burns cleaner than standard oil.
  2. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    I dunno, maybe just bad luck,,,but the one and only time i ran oil designed for diesel trucks/engines, it tore up my cam and lifters within the "oil change" time frame.
    oil drained out looking like BLAAACK water,,,and when the motor was tore apart, the cam was severely worn.
    never ran it since and never had problems with wore out cams.
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Why in God's name do you want to run diesel oil in your gasoline engine? And even better, why do you want your oil to BURN cleaner??? You don't want your oil to burn at all. Just use an oil designed for gasoline engines. You don't see guys running gasoline motor oil in their diesels....and if you do that on something with a warranty, consider your warrnty GONE.
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Been using Delo 400 in everything for about a year. Oil looks like normal used oil coming out.
  5. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    it has more detergents than standard oil and probably lasts longer than standard oil due to the fact that most gas engines do not see the same amount of abuse that diesels do.
  6. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    i run rotella in mine. its not the same brand but its made for diesel engines. its all ive ever ran so i cant really compare it to regular motor oil. i mostly run it because my dad works as a tractor mechanic and gets it for free
