Chevy 203 to Ford NP205
Discussion in 'OffRoad Design' started by WyoJeeper, May 2, 2003.
  1. WyoJeeper
    WyoJeeper Registered Member
    Nov 2, 2000
    46
    Laramie, Wyoming
    Does Offroad Design make an adapter to use the Chevy NP203 to a Ford NP205? I currently run a 350, TH350 to NP231 combo in my YJ and want to keep the drivers side drop.
    Thanks for any info
    RIck
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yes they do, mine should arive any day. To keep the passenger side drop you will have to use a GM case though. I just made a post in the Garage about that very thing...
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Hey Russ, he wants the driver side drop. /forums/images/graemlins/rolleyes.gif
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    /forums/images/graemlins/blush.gif
    Gotta read closer! Your right, got it turned around in my head. In any case, drop to either side, ORD can take care of you... I'll go crawl back under my rock now... /forums/images/graemlins/ignore.gif
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yup, we can mate any 203 and any 205. We can even get a bit crazy with the GM203/ford205 setup and turn both up flat. Or do more standard rotations. This is the combo I have in my K5 and the one we're putting in my brother's buggy.
  6. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    You guys with driver side drops...what exhaust do you have? I Have the Thorley Tri Y's but they are directly behind the pinion on the Ford Dana 60. Which is a bit of a problem when it comes to putting in the drive shaft.
  7. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Mine are JBA's for a vortec big block. I tried a set of flowtech (summit racing brand) shorties for a '92 up sub and they looked like they would work OK for a smallblock.
