chevy 208 fixed yoke
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by drivelineman, Jul 26, 2001.
  1. drivelineman
    drivelineman 1/2 ton status
    Aug 23, 2000
    707
    Well i have found the output shaft for the 208 chevy to make it a fixed style - but the housing appears to be obsolite - i will check on different vendors and see if i can get maybe an old stock part # or aftermarket- i have found there are 7 differnt housings offerd with the dodge case making it real fun to see what will fit the chevy 208- anyone have a dodge case 208- laying around with a casting # might help the puzzel get smaller- Guys I am tring here - i Build drivelines but am tired of the cheesy slip yoke stuff for your fix it just makes me sick not being able to make a tough line when you call with your 6" lift and 83 k5- i will continue to search-
  2. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Hey, thanks for your hard work. We appreciate what you're trying to do for us.
    I'll be calling in the near future for your 1350CV front and rear shafts for NP205 [​IMG]
    Also, the ebrake for the rear dshaft, if it's available...need an ebrake here since I've gone with the rear disk setup.[​IMG]
    Boss
    89' 1 TON of FUN K5
  3. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    jesse this is j.c., i left you a message a while back, will your research work with a 241 also? mine is so dam loud when i let off the gas i think it going to grenade! got to do somthing fast!
  4. ScoobyDann
    ScoobyDann 1/2 ton status
    Mar 9, 2001
    305
    El Paso, TX (Far West Texas near Las Cruses
    I got a friend w/ a dodge 208 lying around. i will ask him ASAP and let you know.
    sun desert offroad http://community.webshots.com/user/scoobydann
  5. drivelineman
    Aug 23, 2000
    707
    cool- let me know - we will have the disk brake set up soon for the 205 and maybe the 241 we will see how the brackets go there-
  6. ScoobyDann
    Mar 9, 2001
    305
    i got some numbers for you
    ok--on the tag we have
    (NPGear 208-D
    4202792
    32481
    ratio 261)
    found a casting # on the case close to the fill and drain plug and it goes like this
    (09104c-13890)
    it came off a 81 3/4 ton w/ a 435 4 spd tranny
    hope this help
  7. Storm Trooper
    Nov 24, 2000
    4,640
    Hey, I say thanks also.
    I'd like to keep my 208 if I can make it better.
    Apreciate all the work, I'll keep watching for lt.
    [​IMG]<font color=red>[/b]"Rid'in HigH in my K5"[​IMG]
    ....[​IMG]<font color=blue>[/b]"6" Lift -<font color=purple>38.5's"[​IMG]....
  8. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    Keep up the good work. Keep us posted.
    Keep it simple!
  9. Sparky87k5
    Sparky87k5 1/2 ton status
    May 6, 2001
    726
    Lynden, Washington, 4 miles from Canada
    Hope you can come up with a fixed yoke 208 swap. Would buy one in a minute.
    87 K5, D60 & 14FF, 5 sp & NP208 & 383 stroker. Build it Bulletproof and take it fishing!
  10. JoeAngelicchio
    JoeAngelicchio 1/2 ton status
    Feb 18, 2000
    628
    South Central Ontario, Canada
    I may consider it too if I don't use a 205 or 241 w/sye.....
    <font color=green>Joe Angelicchio
    <a target="_blank" href=http://community.webshots.com/user/jangelicchio>http://community.webshots.com/user/jangelicchio</a>
    Lisle, Ontario, CANADA</font color=green>
  11. COYOTE35
    COYOTE35 1/2 ton status
    Mar 5, 2000
    140
    Alto, Michigan
    if you need a guinea pig let me know, I'm right in the middle of a build up that I would love to enclude getting rid of my slip yoke. I don't mind working out any bugs to help.
    Whats wrong with big and wide?
  12. drivelineman
    Aug 23, 2000
    707
    today i got a lead on a new part that might make all this slip yoke stuff more easier to deal with- the main problem in my opinion is this - the current cady slip style c/v is cheesy and will not go more than 20 degree's with out problems- but i have a lead on a 1350 series c/v 208 chevy slip yoke being produced soon- i will get more details on monday - but this seems might be a second better idea than the 3r series cad yoke pos-
    Owner of High Angle Driveline http://highangledriveline.com<P ID="edit"><FONT class="small">Edited by drivelineman on 07/28/01 09:16 PM.</FONT></P>
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Can't you just make one? I know you've got an awful lot of equippment, so why not make your own? If you do you can design it however you want. I'll be in line to pay $500 or so for a good shaft next year.
    Tim
  14. COYOTE35
    Mar 5, 2000
    140
    Alto, Michigan
    Let me know. In a week or so I will be replacing my rear axle and will be in the need of upgrading my driveshaft. I would really like to improve it rather than just making it work. I figure since I'm goigh thru all the work to upgrad my axles I might as well fix the slip yoke problem too. I like the weight advantage the 298 has and would hate to have to relpace it with another transfer case.
    Please keep me informed.
  15. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>How much will the 205 p brake be? I want one!</font color=blue>
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I like the low range of the 208s and 241s more than the weight savings. I can deal with the fact that it's not as strong.
    Tim
  17. JoeAngelicchio
    Feb 18, 2000
    628
    Jesse,
    How's the SYE for the 208 coming along?
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Amazing how in 2 weeks you change your mind. 4 speed and 205 here I come.
    Tim
  19. COYOTE35
    Mar 5, 2000
    140
    Alto, Michigan
    any news on the output shaft modifications?
  20. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    I had mine converted by Offroad enterprises in stockton ca....it cost me about 600 for them to convert it over. i havent tried it off raod yet but goin to frank raines today so i will let ya know how it works
    [​IMG]<font color=blue>Donations accepted for the "Build Chaz's 1972 K5 fund"!!!</font color=blue> [​IMG]
