chevy 250 question
Discussion in 'The Garage' started by big_black_blazer, Feb 28, 2005.
  1. big_black_blazer
    big_black_blazer 1/2 ton status
    Dec 19, 2004
    114
    Western Kentucky
    :1zhelp: :dunno: i put a 250 6cyl from a 1972 k5 in my 54 chevy truck. it has started to backfire through the carb and exhaust like it jumped time, but the distributor hasn't moved. the timing gears are still fine, the cam is fine, and the valve train is fine. it is misfiring on all cylinders so i am going to get new plugs, wires, cap, points, button, etc. today and try to start over. could these be the problem? it just done it all of the sudden (over a 10 mile period). if it matters i changed the fuel filter and intake/exhaust gasket the night before, but the gasket is not leaking.
    thanks
    evan:1zhelp: :dunno:
  2. towdriver80
    towdriver80 Registered Member
    Jan 16, 2005
    41
    Maybrook, New York
    Could you have switched a plug wire by accident?
  3. diesel4me
    Jul 24, 2003
    17,568
    942
    Massachussetts
    tune it up and see ---
    It might just have a condensor crapping out,or needs new points,or maybe a cracked distributor cap or rotor--as stated already make sure all your plug wires are on the right plugs(firing order 1-5-3-6-2-4)--the only other thing I can think of is a valve or rocker arm is sticking or something went awry in the valve train,but thats pretty unlikely...good luck..:crazy:
  4. big_black_blazer
    Dec 19, 2004
    114
    Western Kentucky
    thanks for the help. i found the problem--- some how or another, the timing wound up 10 degrees off and i have a hellacious leak between the carb and intake. but i should have it going tonight.
    thanks
    evan
