Chevy 305 in el camino sounds like boat motor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by weisel, May 9, 2001.
  1. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    I was helping my brother fix his starter the other day and noticed that on his factory exhaust system, there is a weird vacume controled thingy on it. It lookes like a vacume controled diaphram moves a lever and spins a shaft in the tube which lookes like it has a throtle plate type thing in it. Try to imagine a vacume controled choke on the exhaust pipe! and it dosn't even have a hose hooked up to it. I just wanted to post this and see if any one has seen this, what is happening in it exactly, and what is it for?
    Insurred by Smith & Wesson
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Oh gawd! I know exactly what it is! I can't think if the name right now!!!!!! ARRRGGGG!!!!! The thingymagig, right!!!!! GRRRR!
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  3. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    ya, the thingamajig...do you know what it dose?
  4. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    heat riser valve!!!!!!!! I think? I dunno what it does. Prolly something when the motor is warming up.
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I believe its only purpose is to block off exhaust on one side to force hot exhaust through the heat riser passage when the engine is cold.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56 Locked
    Soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  6. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I think baddog and mudd'n have nailed it! 2 points!
    1987 Chevy K5 Blazer- 350 TBI
  7. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    My Blazer had one of those. I couldn't believe it when I saw it. Fortunately it was stuck in the open position. I removed it and now I have a set of Flowtech Headers [​IMG][​IMG]
    <font color=blue>//////
    <A target="_blank" HREF=http://blazer79.coloradok5.com>http://blazer79.coloradok5.com</A>
    </font color=blue>[​IMG]
  8. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    it dosn't get cold enough to need a heat riser here so i will just wire it open. thx a lot for the info.
