Chevy 350 carb...
Discussion in 'Parts & Trucks Wanted' started by straycowboy, Mar 6, 2004.
  1. straycowboy
    straycowboy Registered Member
    Dec 19, 2003
    9
    I am looking for a carb to put on my 'Burban. I have a 350 in there. I am looking for something cheap, or to trade anything off of a '79 Blazer. Email me if your interested! Thanks! /forums/images/graemlins/k5.gif /forums/images/graemlins/hack.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i got a rebuilt carter quadrajet. $50
    may trade for the front drive shaft /forums/images/graemlins/dunno.gif
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    this post belongs in the parts wanted forum so ill move it there for you /forums/images/graemlins/thumb.gif
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i have a few good used ones if anyone needs, but i have to know if you need one with:
    intake mounted carb or not,
    th350 or manual trans/th400, or 700r4(82-up)
    cable with round clip linkage, or rod style linkage
    i can rebuild these and have great luck in doing so with these, rochester and carter both,
    what i do is totally disassemble them and pick out the parts that are plastic or rubber and that have to be reused,
    and i soak the three main parts of the carb and also any metal parts that have to be reused, and soak them for a few hours or up to one night,
    i soak them in 5 gallons of carb acid, then i rinse them off with water and air blast them dry.
    then i break out the carb rebuild kit of choice and replace everything that i can that comes in the kit and then i set float level and spray everything with WD40 and then reassemble the carb, and now then its ready to go
