Chevy 350 initial timing?
Discussion in 'The Garage' started by gm guy, Jun 26, 2004.
  1. gm guy
    gm guy 1/2 ton status
    May 1, 2004
    151
    Vancouver Island but work in Ft Mcmurray Alberta C
    I am setting the timing on a sbc, and need to know the stock spec. Any idea? /forums/images/graemlins/dunno.gif
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    for a carbed motor the specs are
    4* BTDC on a 305
    6* BTDC on a 350
    On a TBI motor
    0*
    on a TPI motor
    6-8* BTDC
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    4* on a TBI 454 IIRC, 0* for a 350
  4. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    He asked about SBC's. /forums/images/graemlins/waytogo.gif I will process the TBI 454 into my brain though. Good info to know.
    Harley
  5. gm guy
    May 1, 2004
    151
    OK, thanks. Now were should the vacume advance be hooked up to?
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Which carb are you running ? My q-jet (later non computer with bowl vent to canistor) has vacuum advance on the pass side front near the choke , and works perfect. /forums/images/graemlins/k5.gif
  7. gm guy
    May 1, 2004
    151
    It is a quad jet carb, the vacume was hooked up were you described but there was no vacume at idle. I hooked up vacume from another another outlet on the carb (wich did have vacume) and the timing light showed the same with or without it hooked up. This means the diaphram on the dist is faulty. Right? /forums/images/graemlins/confused.gif
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The vacuum advance is ported vacuum, you don't need it advanced at idle, only on accelleration and part throttle cruise . I would assume the distributor vacuum can is bad . Take the advance can out of the distributor, push on the rod , put your finger on the vacuum nipple and let go of rod , it should stay in one spot until you remove finger ( OR you could suck on nipple to see if rod moves ) /forums/images/graemlins/k5.gif
  9. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Yup. I know my rod moves when I suck on nipples.
  10. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    jus t acall it good tinming whrn two gils and a guy get togthter at the same time i jhoe this works for me kayter
