chevy 350 rebuild
Discussion in 'The Garage' started by crash81, Aug 28, 2005.
  1. crash81
    crash81 1/2 ton status
    Jun 19, 2005
    289
    roxboro,nc
    i have a 90 v1500 suburban with tbi 350 with 250,000 miles on it and it needs facelift. my question is i have a older 350 carb motor that i was thinking of building so i will not have dowtime just swap them out when build is done.question is is there a big difference between the to old carb motor and the newer tbi motor?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    The old engine that you have will have a two peice rear main seal. This means that the oil pan, flywheel and blancer will all be different. The swap can be done. Just make sure that the older 350 has a cam that will work with the TBI or you will have a problem
  3. crash81
    Jun 19, 2005
    289
    roxboro,nc
    are the heads the same?
  4. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    The angle of the center bolts on the intake are different. I have heard that you can redrill the intake to work on post 1987 heads but I am not sure. 1986 and earlier are one angle and 1987 and later up to the Vortec bolt pattern are different.
    Ira
