Chevy 454 to a GMC Jimmy, Help!
Discussion in 'The Garage' started by Billblade, Oct 11, 2005.
  1. Billblade
    Billblade Registered Member
    Oct 11, 2005
    9
    North Carolina
    I have very recently bought a 1985 GMC Jimmy that use to house a 305. The motor was not included in the purchase. I have a Chevy 454 that I would like to put in this truck, but am unsure if Chevy 454 mounts will work on a GMC Jimmy frame. Can anyone help out here? Are the motor mounts universal between a Jimmy and a Blazer, anotherwards are the frames the same on both vehicles. Thanks for the help!
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    a blazer and jimmy are the same vehicle, just different badges.
  3. Billblade
    Oct 11, 2005
    9
    North Carolina
    Thanks big83chevy4x4, I knew the bodies were the same body, but didn't know if the frame holes were the same. Now I can continue my project, thanks!!!
  4. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    Should bolt in...
    I've read some posts saying big blocks use different mount pads-,but I put 3 454's in different 70's GM trucks and they bolted right in using the block brackets off the old small block motors.(4x4 brackets have the thru bolt holes about 1" higher than car ones or some 2wd trucks! you have to use them,or the oil pan might hit the crossmember,and it'll throw off the driveline angles).
    My chiltons book shows the pads on the frame being bolted in the "other" set of holes for a big block,but I never moved mine and everything fit like a glove! :confused: --only truck I had to move them on was my 79 C10,when I put a 305 in place of the 250 six it originally had... :crazy:
  5. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    So a Big block chevy will bolt directly in place of my small block chevy?? :thinking: hmm.... you people are corrupting me :D .. If I can find a deal on a junkyard 454 I may know where my $$ is going ;)
  6. Russ
    Russ 1/2 ton status
    509
    Summerdale AL
    As long as you use the small block clamshell motor mounts it will bolt right in. If you use the larger big block clamshells they have a different bolt pattern and you will have to change the frame brackets. I am in the process of doing this in my dually right now. I found a new set of frame brackets and am going to use the larger big block mounts.
    Russ
