Chevy and Toyota 6-lug Pattern the Same?
Discussion in 'The Garage' started by Ditchdigger, Apr 8, 2004.
  1. Ditchdigger
    Ditchdigger Registered Member
    Mar 11, 2001
    96
    The Great Midwest
    I'm looking at buying some wheel spacers for my rear diff.
    on my 84blazer being the rear is shorter.
    I found some Toyota 6-lug spacers that fit (for example) a 4-runner, but I am wandering if they fit chevy 6lug pattern?
    Toyota, Chevy the same?
  2. ilikemud
    ilikemud 1/2 ton status
    May 22, 2003
    111
    The Farmhouse, NJ
    yea same bolt pattern, but the center hub registar is different... just make sure it is large enough to clear your hub/ brake drum center... also most 6 lug imports isuzu ect..
  3. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    If they are designed for a Toyota, they will fit on the Chevy hubs. The bolt pattern is the same. Stock Chevy wheels will not fit over the hubs on a Toyota front axle though.
  4. Ditchdigger
    Mar 11, 2001
    96
    The Great Midwest
    Oh I forgot, Bolt size and threads the same, or more importantly the bolt size?
  5. Ditchdigger
    Mar 11, 2001
    96
    The Great Midwest
    Anyone know if the Bolts on Toyota spacer right size for the Stock Chevy wheels
    I'm wandering if Toyota uses smaller bolts?
  6. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Toyota uses 12mm studs they are bigger than a 7/16" studs so I don't see putting them on a GM would hurt anything more than the trucks feelings.
  7. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    stock chevy wheels wont fit, but aftermarkets will, you should see a 33x12.50 bfg on a non lifted 4runner with the rest being 235-75-15s lol
