Chevy brochure makers smoke crack.
Discussion in 'The Garage' started by divorced, Jan 17, 2005.
  1. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    It says "New lightweight aluminum transfer case". When I took out my t-case that looked like that it was NOT lightweight.
  2. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Relatively lightweight.;)
  3. dyeager535
    26,975
    Yeah but was yours SILVER? :p:
  4. divorced
    Jul 20, 2004
    5,115
    Actually, it was rusted. Aluminum doesn't rust. I think I got ripped!
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    WAS silver now more of a oil/grime color:D
  6. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    :haha:
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    What's funny about that pic is that the t-case shown is a CAST IRON NP-205. :blush: Only the end cover is aluminum.
    But if you think that an aluminum t-case is heavy, try to hold onto an NP-203 as you unbolt it. THAT sucker is heavy! :yikes:
  8. divorced
    Jul 20, 2004
    5,115
    Yep, that's the point that I was sarcastically making. You think that someone would catch that before it went to print? It was for an '81, I guess the first year of the 208. I've had them all out and back in. My first 203 fell to the ground and then I did the "hoist through the floor" trick to get it back in. :D
  9. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    I was glad when I removed the th350/203 combo from a bud's blazer a long time ago I wasn't underneath it!!! Weighs more than a sumo wrestling team I swear!
  10. big94gmc
    big94gmc 1/2 ton status
    Sep 1, 2004
    3,651
    No VA.
    No, no, no, no..... That just means the CASE is light weight. Once you put gears, shifters, and lube in it, well, that's a different story!!
    HAHAHA!!!:grin:
  11. dyeager535
    26,975
    The service manuals tend to be the same way...you'll see what is obviously a drawing of a pre-72 truck used to illustrate something on a '73+.
    GM isn't creative. :)
  12. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yep
    even service manuals are this way sometimes
    and other companies like haynes, MOG they are way off base on alot of thjeir info/diagrams/illustrations
    good luck
  13. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    I like the part where it says able to shift from to 2 to 4 WD at speeds less than 20 mph. My 70 owners manual says any speed.
  14. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    they didn't expect people in pickups to be doing a 110 back then ;). 55 is what seems to stick in my head on the newer cases. I kicked mine out of 4 hi today at about 60. Doubt that matters though since I was going out of 4 into 2. And if you are talking about a 203 wouldn't they be shift on the fly since they are full time 4x4? its already engaged, nothing to synchronize.
  15. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    Lightweight compared the the NP205 HOG.
