Chevy/Ford Dana 60
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by AZK5, Apr 4, 2000.
  1. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    Does a Ford F250 with the Dana 60 front axle have 6 or 8 lugs? If it has 6 lugs does anyone know if you can put a Ford F250 Dana 60 6 lug hub and rotor on a GM Dana 60 spindle?
    CB
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Ask the folks at http://www.dynatrac.com
    they are the D60 leaders. Of corse they will try to sell you a 2500 dollor front axel.
    Let us know if you find out
    Rock ON![​IMG] 72 K5 [​IMG]
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    You may need to put anti-rejection drugs in the gas tank if you go with a F$%D part!!!! LOL [​IMG]
    '79 - 406 w/IROC TPI - K5#5 - a <font color=orange>sickness[​IMG] <font color=blue>you never get enough of!! [​IMG]
  4. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Biggest problem with using a Ford Dana 60 is that the diff is offset to the drivers side unlike Chevy and Dodge that have it on the passenger side. Your easiest route is a Chevy Dana 60 front. It's a direct bolt in and I think all Dana 60 fronts are 8 lug unless its a custom job like Dynatrac.
    Good Luck
    Brian
    Still in search of the TBI KING!!
  5. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Ford has never used 6 lug on anything. Half tons are 5 lug, 3/4 and 1 tons are 8 lug.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  6. AZK5
    AZK5 1/2 ton status
    Feb 22, 2000
    448
    Chandler, AZ
    Thanks Tim that was the answer I was looking for. I called Dynatrac first, are you ready? A Dana 60 with any gear, a Detroit locker, 6 lug outers, 35 spline inner and outer axles, Warn Premium hubs, a crossover steering knuckle installed, delivered to my house is: $4789. They will sell me the 6 lug hubs to fit on a stock Dana 60 of my finding for $500. That is why I'm looking into building up a stock Dana 60. The good news they will sell me the reverse rotation Dana 60 front axle for almost the same price.
    CB
  7. Burt4x4
    6,854
    WOW........[​IMG]
    I guess my original guess of 2500 was totaly WORNG!!
    OOUUCH!!4800 smakers[​IMG] shoot I payed lees than that to get my rig.... Well scratch Dynatrac off the list of thing I can afford.........[​IMG]
  8. Rockblazer
    Rockblazer 1/2 ton status
    Feb 18, 2000
    114
    South Dakota
    Ford never made 6 lug, and you can't inter mix Chevy and Ford outers. Ford outer stubs are if I remember correctly, 2" shorter than Chevy. So that shoots combining the hubs. However everything else is the same. Now the way to do it cheaper... buy a Ford center section and weld the tubes from a Chevy or Dodge 60. Ahhh now you are talkin'! Reverse cut gears, nice high pinion and uh oh yeah those danged 8 lugs! Oh well... good luck!
    Todd
    Rockblazer
    "You're Right... I don't understand that jeep thing!
  9. 88Jimmy
    88Jimmy 1/2 ton status
    100
    Las vegas, NV
    Now you know why they are called DynaRape
