chevy front 60 front 410s and eaton with locker $1300
Discussion in 'Pacific Region' started by bigbadburb, Mar 17, 2003.
  1. bigbadburb
    bigbadburb 1/2 ton status
    Nov 13, 2001
    176
    vancouver wa
    the front end is totally dissasembled but i have everything to put it back together except you might want new calipers and the tie rod is probally shot. The other set of axles with 456s 60 front and rear with a traclock in front and a 60 rear with powerlock are still available for $1800 and dont have very much usage and are still completely together also .
  2. bigbadburb
    Nov 13, 2001
    176
    vancouver wa
    Re: chevy front 60 456s and dana 60 rear $2000 lockers
    very little usage on both since rebuild from what i understand. and if someone would rather have 410s and a eaton with a locker i would lower it to 1500 but then you would have to put the front end together and would be missing a couple of things( hubs,tie-rod)
  3. cornfed
    cornfed 1/2 ton status
    Oct 15, 2001
    295
    washougal wa
    Trade for a lifted 72 3/4 ton pickup bed trailer?
  4. bigbadburb
    Nov 13, 2001
    176
    vancouver wa
    no but maybe if you had some of those closed knuckle drum brake early military axles we would have a deal! Too bad you aint got none of those huh?
  5. cornfed
    Oct 15, 2001
    295
    washougal wa
    Yeah you definitely wouldnt be interested in the other military axles thatll be here this week, and those closed knuckles wont be available for probably a couple years, unless youre interested in spending every night working on a really old suburban, in which case they would be available for you much sooner!
  6. BadBowtie1
    BadBowtie1 1/2 ton status
    Nov 5, 2002
    456
    Mill City,OR
    I have a set of closed knuckled 2.5 ton axles.Its all under a frame too.All set up for chevy motor.It has a tranny,t-case and the PTO on it still.Also has 48" tall tires.
  7. bigbadburb
    Nov 13, 2001
    176
    vancouver wa
    ttt
