Chevy/GMC 4 wheel drive front axle
Discussion in 'The Garage' started by tryme, Jan 3, 2004.
  1. tryme
    tryme Newbie
    Jan 3, 2004
    Iam in the process of building a early model 4-wheel drive. But would like to install a later model chevy small block and trans. Willing to use a standard or automatic 4x4 trans. The trucks front third member & drive shaft is on the pass.side,not drivers side of the truck. Did chevy make a transmission,that the front 4x4 driveshaft can be on the pass. side. tracymart@hotmail.com
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    yep....i think from 67 and up are all on the pass side, maybe even sooner than 67
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Not really sure on what you are asking, but here is what I know (I think) Chevy switched from passenger side drop to driver side drop in 88 IIRC when the pickup bodystyle changed. Prolly your best option is to run the late model motor that you want which should still bolt to your tranny (unless there is a specific reason you want a late model tranny) then you don't even run into the front axle driveline problem. Other option is to run a Ford front axle which has driver side drop (high pinion Dana 60) is the prferred axle people use when they do a solid axle swap in the late models. Hope I helped some and didn't give you any bad facts /forums/images/graemlins/thumb.gif
  4. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    the options are endless just tell us what kind of motor you want to run and we can tell u a bunch of trans and tcase options alot of Chevrolet stuff is interchangible
