Chevy questions.....pop quiz...
Discussion in 'The Garage' started by hi pinion, Nov 10, 2004.
  1. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Ok guys pop quiz......how many types of trucks,including stepside trucks, from years 73, 74 , 75,.....did gm Make??? I want to find a cantidate with 3/4 ton running gear already underneath, 350 turbo 400, and 205 or 203. I am going to try and utilize the 3/4 ton stuff, tranny, etc to do a cheap build. Can you guys lead me in a direction??? I was thinking long bed. What trucks came with all this, and 4:10s stock???? /forums/images/graemlins/ears.gif
  2. hi pinion
    Sep 25, 2003
    5,354
    Re: Chevy questions.....pop quiz
    The goal is to dodge the Cali smog rules, so i can only go up to 75. I wanted to use all the existing stuff, mabey put on a 4 lift and some tires, and be done with it. /forums/images/graemlins/thumb.gif So, something that has 3/4 ton. a 400 , 14 bolt, someone has to know a good cantidate i could start with ....... /forums/images/graemlins/thumb.gif
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    prolly a 80's long bed 3/4 ton, some came with the TH400 np208 compo, 14bff or semi float, 8 lug 10b front /forums/images/graemlins/thumb.gif
    saw one at the junkyard this past weekend, wanted $700 for the whole thing /forums/images/graemlins/waytogo.gif
  4. hi pinion
    Sep 25, 2003
    5,354
    no, has to be 75 and under. Mabey even 60s /forums/images/graemlins/ears.gif im going old school /forums/images/graemlins/thumb.gif
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
  6. hi pinion
    Sep 25, 2003
    5,354
    Thanks for the time, i was thinking like500- 1000 bucks range /forums/images/graemlins/histerical.gif some beater. /forums/images/graemlins/thumb.gif BTW im checking out a 75 c20 tommorow, anything i should check???? I want 4 10 gears , a 400, 3/4 ton. Thats it /forums/images/graemlins/thumb.gif I was thinking sand it down and primer black or grey /forums/images/graemlins/peace.gif /forums/images/graemlins/thumb.gif
  7. hi pinion
    Sep 25, 2003
    5,354
    COMMON GUYS!!!!! What about GMC??? This is ck5 isnt it?? /forums/images/graemlins/histerical.gif /forums/images/graemlins/thumb.gif
  8. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Just so You know in January 76 models wont need to be smogged /forums/images/graemlins/deal.gif
  9. hi pinion
    Sep 25, 2003
    5,354
  10. hi pinion
    Sep 25, 2003
    5,354
    BTW, the main goal is to utilize the 3/4 ton stuff, the tranny. the running gear and gears .4:10 work fine with 35s /forums/images/graemlins/ears.gif a cheap build. Witch one of these would be a good cantidate?? I like the longbed, but anything other than a k30 wont have the 1 ton stuff. And those you cant find anymore /forums/images/graemlins/thumb.gif
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I thought the rolling exemption stopped?
  12. hi pinion
    Sep 25, 2003
    5,354
    [/ QUOTE ]I dont think it did /forums/images/graemlins/confused.gif
  13. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Your only choice is a 3/4 ton 4X4 to get the drivetrain you want. They did not use a TH400 in 4X4s in your year range, I don't think (maybe in 75 or 76?). They are all long beds - fleet or step sides are out there (a lot more fleets).
  14. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Go for a '75-'76 3/4 ton 4x4 Chevy pickup. They will have either a 350,400,454 and should be a th400. AVOID ONE WITH A 203! You don't want full time 4wd. If you don't need a 4wd I have a '76 C30 1 ton dually if you are interested. OK, black and silver paint, low mile 454, brand new built th400, D70HD, and 4.10's. It's a camper special. $3K.
  15. nvrenuf
    Jan 7, 2002
    13,088
    252
    Mobile, Al.
    Since you're wanting the 3/4 ton stuff you're confined to 2 models (in each brand) for those years - fleetside and step side (both long wheel base).
    There are no short wheel base 3/4 tons and the true 1 ton 4x4 was not introduced until 77.
  16. hi pinion
    Sep 25, 2003
    5,354
    This is all fine and dandy, but , can you guys give me like a certain number like C-20 ???? Whats the deal on that??? Or just any longbed fleetside/stepside? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/thumb.gif
  17. hi pinion
    Sep 25, 2003
    5,354
    OR.......what about an old deisel?????? /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  18. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Your best bet to me would be to piece together a truck. No GM 4WD in the years mentioned came factory with a TH400, but you could find a 400/208 combo and swap it in. I would look for a 73-76 shortbed(for better wheelbase) 1/2 ton, convert to 3/4 ton with a 14B rear (FF or Semi float), put some lower gears in it, do a poor mans Doubler (TH700/NP208), and go wheeling. You could do it for cheap, keep it smog legal, and have fun.
  19. hi pinion
    Sep 25, 2003
    5,354
    [/ QUOTE ] Yeah brother ,that was the idea, but that sounds like too much work /forums/images/graemlins/histerical.gif i just wanted something i could lift and put 35s on. /forums/images/graemlins/waytogo.gif i know this is way off the beaten path but i had my eye on this one [​IMG] it could be another plumbing truck ,and a wheeling machine /forums/images/graemlins/peace.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/thumb.gif I wanted something with 3/4 ton,and 4:10 primarily /forums/images/graemlins/waytogo.gif
  20. hi pinion
    Sep 25, 2003
    5,354
    Whell i looked at a 75 longbed, a scottsdale, i took some numbers down, it appears to be a camper special,i wish someone could tell me if its worth buying.......the right transfer case, etc. /forums/images/graemlins/whistling.gif /forums/images/graemlins/waytogo.gif
