Chevy rearends question
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Silverado_K5, Oct 14, 2003.
  1. Silverado_K5
    Silverado_K5 1/2 ton status
    Jun 4, 2003
    707
    Weston, Oregon
    I'm wanting to know if the 67-72 Chevy 4x4 front and rearends can be swapped out with 73-up front and rearends? Do they have the same spring pad width? Is there any difference in the lower shock mounts? I know the pinion yokes are different and would require an offset u-joint, but need more info. I'm trading my 89 K5 lifted Blazer for a 68 Chevy SWB 4x4 pickup and it has 5.13 gears front and rear with detroit lockers in each rearend. I want to go to 4.10's, but want to know what my options are.
    Thanks for the help,
    Doug
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The fronts have the same mounting points but the pre-73 stuff has small D30 sized u-joints (260x) unless he has swapped the shafts.
    The rears have different spring pearch width (40in vs 42in or something like that...the older stuff is the same sepperation as a 73-up 1-ton) and the shock mounts are different as well.
  3. cornfed
    cornfed 1/2 ton status
    Oct 15, 2001
    295
    washougal wa
    Is your rearend 3/4 ton or half ton? If its a factory 3/4 ton Ill buy it if you swap it out.
