Chevy Snow-Blower
Discussion in 'The Lounge' started by Fubeca, Dec 8, 2005.
  1. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    A buddy just emailed me this :D
    If you're tired of anemic, one-lung snow blowers with their slipping drive belts, you might consider Kai Grundt's V8 snow blower which raises the bar on the traditional snow blower in every respect. With electric start, electric block heater, antifreeze heater and eight cylinders, it has no drive belts to freeze up and you'll never get bored with the job as the 454 cubic inch big block Chevrolet V8 produces 412 horsepower, 430 foot pounds of torque and can throw snow 50 feet at just 3500 rpm. Nor will you get cold as the machine has been ingeniously designed to route the engine coolant through the handle bars, with the rear mounted, enclosed radiator keeping the operator nice and cozy.
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    That is sweet, Would like to see it in action.
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Finally.....a good use for a 10 bolt.:D :D :haha: :haha:
  4. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I bet he uses the engine for his lawn mower in the summer:haha:
  5. ak bandit
    ak bandit 1/2 ton status
    Sep 10, 2004
    386
    Eagle River, Alaska
    The exhaust ports look like a small block's...But I cant really tell from the picture.
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    ya looks like small block exaust, but big block valve covers
  7. diesel4me
    Jul 24, 2003
    17,584
    945
    Massachussetts
    I want one!...
    That thing is T**S!:bow: :bow: .I like the chevy diff used to drive the augers..must be a "Lincoln Locker!"..the heated handlebars and rear radiator must be nice for comfort too....ever since I saw a "Walter Sno-Fighter" in my old hometown,with a snowblower 10' high,and 8 feet wide powered by a 366 chevy BB industrial motor,I've wanted one like this one pictured..one thing for sure..drifts will no longer be a problem!.:D
    --pulling it back to the shop if it stalls wuld give you a heart attack though..
    I wonder if it has a doubler and reverse.?:thinking: :crazy: ..
  8. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    "The first point to make is that this is not a V8 grafted on a traditional snow blower carriage but a purpose-built unit crafted around a motor of this magnitude. It functions very much like a traditional blower by way of operator input and feedback and offers effortless safe operation.
    Manouevering the massive beastie (it has a total wet weight of 912lbs) is a snack thanks to the hydraulic-drive 4WD skid steer on independent walking beams which offers a zero turning radius. It’s also as fast as you like, with an infinitely adjustable speed range on the drive wheels via dash mounted flow control. At the opposite end of the scale, it has more than enough torque to pull your car out of the ditch before the hydraulic motors stall!
    Adding to the well-balanced feel of the unit, just 15 pounds of down force on the handlebars will lift the auger blade off the ground in order to climb stairs/walkways for ease of snow removal. Safety has and continues to be paramount with spring return to centre "fail safe" type directional controls with emergency stop and tether cords.
    Safety is one of the key theme, with a flashing blue light (as required by law in many areas) being the least of the safety features. No-one will fail to hear you with those twin throaty exhausts, which come standard with 92 decibels at the controls, though if the rhumba of a V8 exhaust is music to your ears, you can obviously go much louder. Evan at the standard baffling, hearing protection is strongly suggested.
    The powerful yard machine lights and a dashboard with backlit gauges complete the package to ease the burden of this normally reviled task
    The custom 42 inch, two stage auger has a Chevrolet 10 bolt truck differential with spool and a centrifugal auger clutch with shear pin protection, further adding to the image of this “automotive theme blower.” As each unit is cutom-built, optional extras for the snowblower are both diverse and outrageous as the base unit – there is unlimited auger choices from single to multi stage designs and various motor combinations to suit the religious preferences of the customer (Chevy, Dodge Hemi, Ford) and such exotica as a V-10 or a diesel engine or remote starting can be accommodated.
    And if, after a while, you feel you’ve outgrown the 400 horses, this particular engine is well catered for in the performance modification area, with Lunati camshaft, Milodon Gear drive, Holley and Edelbrock components to name a few, and there’s always the fuel injection option too, if you feel you need to throw the snow out of the county or ensure your seat in the “neighborhood blower blingster hall of fame."
    The V8 Snowblowers site can be found here, and if you’re interested in purchasing one of them, drop Sale Manager Kerry Phibbs an email."
    Article can be read here: http://www.gizmag.com/go/4889/
  9. diesel4me
    Jul 24, 2003
    17,584
    945
    Massachussetts
    Now THATS a snowblower!...
    V8 Snowblowers !!:bow: :bow: ..I like the site..the "sitepal" is almost as much fun as the snowblower!.... I'm wishing I hadn' scrapped that 12 bolt posi I had now..could have been my auger drive!:wink1: .
    I have a 26" Craftsman 3 stage snowblower that snapped the crank on its 5 horse Tecumseh motor off flush with the block last winter..and I still have the 400 SB from my 74 K20...and a 500 Caddy motor and TH400,
    out in the shed.. hmm.:thinking:
    Naaah...I'll save them for my truck,or probably sell them...but I also have a 25 hp ONAN 2 cylinder out in the shop,that would nearly
    be a bolt on....:thinking: :cool1: ...
  10. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
  11. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    That looks fun! Now I wish I lived an area that got snow regularly so I could be using one of those right now!
  12. sweetk30
    Nov 1, 2004
    25,554
    548
    horseheads , ny 14845
    thats a big block with threw the hood style headers. the center ports are bend close to each other and look like sbc headers.
