Chevy Steering box, how to adjust?
Discussion in 'The Garage' started by uglychevyZZ4, Mar 25, 2011.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    i have a 91 burb with some slop in the steering box, i have heard you can snug the hears up and remove some slop, and others have told me only a tiny bit not enough to matter, whats the real deal? and how?
    also im in WA, if anyone has a 6lug axle set or rear with 456 email me! wgno@comcast.net oh and hi, long time no log in :D
  2. owenst7
    owenst7 1/2 ton status
    Feb 12, 2008
    1,449
    Anchorage and Reno
    There's a nylock on top of the sector shaft cap on the top of the box. It locks the sector shaft in place vertically. You can adjust that Shaft depth with the Allen bolt in the middle of that nylock. You can also adjust the worm gear preload by removing the rag joint and turning the nut on the input shaft with a spanner wrench or similar (Allen key and hammer can be used). I think proper preload for the input shaft is about 9in lbs rotating resistance.
    You could just rebuild it. Kits are usually under $40 and most parts stores have them.
    As to how much...if it just feels "loose" at the input, this may help. If there's any noticeable play in the bearings though, it probably needs the bearings replaced.
  3. DokWatson
    DokWatson 1/2 ton status GMOTM Winner
    Dec 10, 2010
    426
    Alaska
    He got it while I was typing ^
  4. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    so do i just turn the hexnut and wiggle the steering wheel til it cinches up some slack?
  5. owenst7
    Feb 12, 2008
    1,449
    Anchorage and Reno
    No, you need to put a wrench on the nylock (believe it's 5/8") and turn the allen bolt in the center with a (believe it's 3/8") allen key. That will adjust the vertical position of the sector shaft. Shouldn't need to mess with the steering wheel at all. You're setting the depth to adjust the tooth contact kind of in the same way you adjust pinion depth with a ring and pinion. You should be trying to lower the sector shaft to tighten up any slop between the rack and sector shaft.
  6. sweetk30
    Nov 1, 2004
    24,808
    148
    horseheads , ny 14845
    unless you realy know what your doing you can BLOW up the box.
    search steering box adjustment with 4x4high as user name under advanced search. he has rebuilt lots of boxes and posted super info on adjusting them.
    and check all the front end parts first. tie rod ends/pitman arm if 2wd/ball joints. prob find somthin there first.
    also the stock steering shaft has a slip/box on the steering colom end that gets worn. comon upgrade is the jeep steering shaft swap.
    realy look over the whole system with 2 people first before playin with the box.
  7. ARAMP1
    ARAMP1 Aviator Extraordinaire Premium Member
    Sep 1, 2005
    3,974
    17
    Memphis, TN
    Here you go! :thumb:
  8. KansasTwister
    KansasTwister 1/2 ton status Premium Member
    Jun 19, 2009
    2,733
    Lawrence, ks
    sweet, mines leaking like a mofo. Thinking about just replacing the seal and seeing how long she will go for.
  9. Keitha
    Keitha 1/2 ton status Premium Member
    Oct 13, 2008
    920
    Costa Mesa, CA
    I had about 25 - 30 degrees of slop in my wheel. All tie rods etc were in good condition. I tightened the adjuster screw on the top of the gear and it helped a lot. I probably only tightened it about 1/4 turn.
  10. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,077
    Bangor,Pa
    i heard you bottom out that adjuster with a alen key then back off half a turn.should help a lot.i havent tried it yet,but i think that will get you in the ballpark.
  11. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    the issue is the box gear wear at the straight ahead position since they spend most of the time there. if u over tighten it in that position it can bind closer to the lock position and break the box.be sure to check for binding at larger turning angles.
