CHEVY TRANNY TRANSFER GURUS...WTF IS THIS???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Brians 60s, Nov 15, 2001.
  1. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    Trying to ID this tranny and t-case combo and have no clue what it is. The transfer case is an aluminum borg warner driver side drop. the adapter is the round style and the only number I could find on the adapter itself is 18306 in the casting. the tranny is a manual with np for new process on a couple of spots on it. The tranny is cast iron with an aluminum top. on the tranny it is stamped np then a box with a w in the middle and a (c17321) and a c-16812. I know this came out of a chevy, but other than that have no clue. It was in a fire, but did not get totally hot as the t case is in perfect shape and the aluminum top of the tranny did not melt, but any stickers or things like that are gone. WTF is it?
    IT'S A 1 TON THING.... IF I HAVE TO EXPLAIN IT, YOU WOULDN'T UNDERSTAND!!!
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    Sounds like a NP435 and a Borg warner T-case...but that's Ford. [​IMG]
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  3. Here is a list of all GM transfer cases made by BorgWarner that I know of:
    I found this info on some GM style BorWarner transfer cases so I would try this:
    Bravada, Syclone, Typhoon cases are:
    1990-95 BW1372 or BW4472
    4.13 Front Output Mounting flange 32 spline rear output 5" Front output circular yoke
    1996 BW1372 or BW4472
    32 spline rear output, 4.90 front output Mounting flange
    K-Series cases
    89-93 BW1370 or BW4401 w/Two-position switch Fixed rear output yoke
    94-96 BW1370 or BW4401 Fixed flange front output w/Three position switch Fixed rear output yoke
    94-96 BW1370 or BW4401 Fixed Yoke Front Output w/Three-position switch Fixed rear output yoke
    89-93 BW1370 or BW4401Slip Rear Output Yoke w/Two-position switch
    94-96 BW1370 or BW4401 Fixed flange front output w/Three position switch Slip Rear output yoke
    94-96 BW1370 or BW4401Fixed Yoke Front Output w/Three-position switch Slip Rear output yoke
    94-96 BW4470 Fixed Yoke Front Output w/Three-position switch Fixed rear output yoke
    89-93 BW4470 32 spl front input fixed front output yoke w/Two-position switch Fixed rear output yoke
    94-96 BW4470 Fixed flange front output w/Three position switch Fixed rear output yoke
    89-93 BW4470 Slip Rear Output Yoke w/Two-position switch
    [​IMG]<font color=red>BigBurb[​IMG]
    <font color=purple>I Like my Burb'n on the ROCKS !!
    <font color=black>Imported to Kentucky through military channels !!
  4. Grim-Reaper
    7,385
    Atlanta
    There are some threads on the POR board about cases you might want to go hunt down. It may out of a 87-91 truck (new body). There is also some aluminum top 465's that were around about the same time. I would do a search on NV4500 and 3500 and see if you can find some pictures. You may have just scrored you a 4500
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  5. Brians 60s
    Jun 12, 2000
    1,115
    Bend, Oregon
    update.... I found the truck it came out of. a has to be 1992 or newer 4 door crew cab. This may help some of you, but I am doing a search now. thanks for all the help guys... Brian
  6. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    a n203 maybe but i dont really know what im talking about
    79 Jimmy, 5" lift 35 M/T with a 383 puttin out 400hp and 450lb/ft. Locked front and back.
  7. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    NV 4500 has an aluminum top...and was introduced in 92.
    Rene
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Fact that it's from an '88 or newer bodystyle explains the driver output.
    Tim
  9. wow, if it has a drivers side drop t case you can drop it in one of your IFS rigs for a super fly mall cruiser![​IMG]
    <font color=blue> Experience enables you to recognize a mistake when you make it again.
    </font color=blue>
  10. Brians 60s
    Jun 12, 2000
    1,115
    Bend, Oregon
    I was told by the dealer it is either a getrag or a nv4500
  11. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    Easy to tell the difference between the getrag and the NV4500. The Getrag is an all aluminum one piece 5 speed with a regular first gear instead of a granny low. It looks like an automatic...The NV4500 has a separate Bell housing and an aluminum top plate with a cast iron case. It also has a PTO provision on the drivers side.
    Rene
  12. all right, brian, where did you get this thing? what are you scheming now? driver's side drop, huh? maybe a dodge front end with coil suspension to boot, grannie low and od? sounds like a cool combo. lets see though, the truck was in a fire but some how the trannie is ok? Hmmmmm....sounds fishy.[​IMG]
    </font color=blue>
  13. Brians 60s
    Jun 12, 2000
    1,115
    Bend, Oregon
    thanks rene, it does have the aluminum top case and cast iron housing, so that kind of answers my question. what threw me off was np all over this thing. I thought new process and new venture were diferent companys.
    Jason, this truck is crispy, found parts of it in powell butte. the cab and engine compartment are toast, but the t case is perfect and the aluminum on the top cover of the tranny did not melt or warp. It shifts great in all gears, there is even a rubber breather on top of the case which is hard, but still there so I think it would be ok. Any word on that zilla? I have a new holley with your name on it.
  14. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    New Process Gear was originally owned by Chrysler Corp. Sometime in the early '90s, GM bought into the company 50%, and the name was changed to New Venture Gear. I would guess that the NV4500 was designed while it was still New Process Gear.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
