Chevy TSB for floor pan cracking - idea
Discussion in 'The Garage' started by rcamacho, Oct 11, 2006.
  1. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Probably old news but it occured to me this evening that a simple solution for K5 floor pan cracking around the seat mounting area would be to run a longitudal cross member under the floor between the cab body mounts. I was thinking a simple piece of U or L channel welded between the body mounts and spot welded around the tack welded nuts would do the trick.
  2. dyeager535
    26,982
    191
    I think tying the body to the frame in that manner would have some pretty bad consequences. If anything during flex the brace would twist the floor with it and fatigue everything connected.
    The problem is perhaps (no offense folks) overweight individuals, and putting a plate INSIDE the cab, (think fenderwasher) but underneath the seat pedestals would spread the load better. Seats still firmly attached, but the weight isn't being carried by the small contact patch of the seat pedestals.
    It may not be a personal weight issue, but it's plausible...I've never heard of the problem before.
  3. sarasotausmc
    sarasotausmc 1/2 ton status GMOTM Winner
    Dec 16, 2003
    769
    Jacksonville NC
    Mine is cracked as well. I put 3/8"x1.5" steel strap about 2 feet long extending slightly forward, but maybe 9" to the rear of the seat underneath the seat mounts themselves. It took the stress off the cracked area enough that it hasn't gotten any worse in the past 6 months I've been driving it. And yes, it has become more temporary than originally intended. I'll post a pic later after work.
  4. rcamacho
    Jul 1, 2004
    1,324
    WA
    I'll have to take some pics. I'm not suggesting tying in to the frame. Rather, running a longitudal brace from the floor support/body mounts (body, not frame) underneath the seat/floorpan.
  5. dyeager535
    26,982
    191
    Ahh, ok, I get you now. Was thinking along the lines of the frame side of the body mounts. :)
    I don't daily drive my truck either, so perhaps its just a problem on trucks that are always being used rather than weight concerns. The seat pedestals DO have a small load bearing surface though, and the K5's seats are particularly far away from the floor pan, which does provide for more leverage on the floor mounting locations.
  6. Col_Sanders
    Col_Sanders 3/4 ton status
    Apr 27, 2005
    5,688
    KFC
    I am the only person driving my truck (weigh 175lbs). The owner before me was also fairly small. Dont think the weight thing is the issue. I am going to have mine welded or may just weld in floorpans myself if I can get my hands on a welder. When I put in new seats I am going to use a nice big washer to spread the weight. Think that should do the trick.
