Chevy with 21.5 inch lift!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Feb 19, 2002.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
  2. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    hahaha... i give them 10 bolts 10 minutes... hahaha
  3. 87superblaze
    87superblaze 1/2 ton status
    Mar 12, 2001
    104
    Upper Michigan
    10 BOLTS and 44's!!! I can't believe it!!
    My Truck <a target="_blank" href=http://www.community.webshots.com/user/nicksm79>http://www.community.webshots.com/user/nicksm79</a>
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Check out the front blocks
  5. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    man that invisible front driveshaft is cool! I wonder where i can get one of those?
    Justin
    Austin, Texas K5'er
  6. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    now that is a idiot rig
    <font color=purple>79' K-5 396cid 600hp, TH350, NP203</font color=purple>
    <a target="_blank" href=http://blueknight.alloffroad.com>http://blueknight.alloffroad.com</a>
  7. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    I would pay 5 bucks to just see him try to get in it....
  8. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    What a piece of junk. Not as bad as some show trucks I've seen, but still stupid. I think the 10 bolts and 44" Boggers aren't the best combination. I tried the invisible front driveshaft trick one time, but I couldn't ever get the front end to pull. LOL!
    Will
    '72 C10, originally 2WD, 6"Springs f+r, Dana 60 f+r, Lock-Right front, welded rear, 4.56s, 350, SM465, NP205, 39.5" TSLs, ORD crossover steering
  9. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    i am offended by that.
    Sun Desert Offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
    83 Chevy, 350, sm465, lincoln locked14ff, dana 60,4.56's, (sometime soon flatbed,and 39.5" TSL's)
  10. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=blue> Can you say DEATH TRAP !
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
    <font color=purple> monkeys steal my underwear at night
  11. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Definately for the open minded. I also saw the giant front lift blocks.
    I had to laugh when I thought how someone could think this was a cool/good idea. "Hey Phil I'm gonna lift my truck 21.5" inches and put 44's on my ten bolts..."[​IMG]
    Not for me, but I'm sure someone will buy it.
    John
    <font color=blue>"When all else fails, read the instructions, or get a bigger hammer"</font color=blue>
  12. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    <blockquote><font class="small">In reply to:</font><hr>
    BUYER PAYS FOR SHIPPING BUT I WILL ASSIST IN LOCATING A LOCAL SHIPPER. PLEASE E-MAIL YOUR QUESTIONS PRIOR TO BIDDING. THANKS
    <hr></blockquote>
    Thank God fer that, I wouldn't drive it across the street.
    REAR END MAY NEED CHANGING IF TRUCK DRIVEN ON HIGHWAY DAILY
    <hr></blockquote>
    Gee thanx for the warning.
    What we have here ladies and gents is a genuine $4000 lawn ornament.
    I can't believe that some one spent over 2K on tires and wheels for some thing that you can not even drive.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  13. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    thats funny
    <font color=red>K5: Because size DOES matter</font color=red>
    85 K5 4IN LIFT 35 GOOD YEAR WRANGLER MT/R, AMERICAN RACING WHEELS
  14. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Ok, so that aint exactly even a useful truck.. but are the 10 bolts really really that bad? I thought what made the 10 bolts weak was the splines and the axle housing flex.
    Wouldnt a good truss + Floater kit /upgraded splines fix that problem? Seems like a pretty decent way to do if if your not gonna go over 35's
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I have seen a 12 bolt hold up to 44s for about 6 months, but it had 2.73 gears.
    That is the most pathetic looking POS I've ever seen though. Lifted stepside? What a joke!
    Tim
  16. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    10-bolts have several weak points besides the ones you mentioned. One is axleshaft diameter. Its as small as they come for our trucks. Second is the c-clips. If the shaft breaks, the wheel will depart from the truck. With a FF, it will at least stay under the rig. Another weak spot is the size of the ring &amp; pinion. The ring gear is only 8.5" in diameter versus the 10.5" gear of the 14B. A 4.56 gear set has the same number of teeth whether it is a 10-bolt or 14-bolt version. So, with a smaller gera itself, the teeth on the 10-bolt will have to be much smaller to get the same count as they would on the larger gear. And, as the gear gets higher numerically, the pinion gets smaller. It, too, becomes a breaking issue.
    10-bolts can work under our rigs. I run two of them fully locked with 35s. The key is to watch the amount of torque applied. Torque is what kills the 10-bolts. That is why most people wouldn't go over 35s with a 10-bolt as the torque required to move the meats becomes too great.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  17. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    <hr></blockquote>
    No. the very fact that he spent the $$$ to upgrade 10b's that are running 44's is a testament to the fact that the owner of that rig only has 3 brain cells and they are all fighting.
    10b can be good for 35's and under. that is it.
    and that is not a good truss. that is a bling-bling truss. for gawd's sake it is chrome!
    -zakk
    World's Fugliest 1-Ton '77 K5
    [​IMG] CK5's Moab 2002 or Bust!! [​IMG]
  18. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    My intial urge is to buy the truck just to save it.............remove the chrome, 44" tires, and make-shift lift and replace them with a nice 4" lift and some 35's. I would love to have a clean stepside.
  19. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=blue> Somehow I don't think it would be that easy !
    L8r,
  20. StonerK5
    StonerK5 1/2 ton status
    Feb 13, 2002
    183
    Phoenix Arizona
    That's just plain wrong!
    "Whatever happened to my Rock N Roll?"
    IM nOt wEiRd, i jUsT lOvE tHe sHiFt kEy!!
