Chewing up starters .... help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by flynhi, Apr 9, 2003.
  1. flynhi
    flynhi Registered Member
    Jan 29, 2003
    24
    Tracy, CA
    I have installed 2 starters in 4 months, I am guessing that the flywheel teeth are rounded and are chewing up the starter teeth. anyone heard of this or am I installing them wrong. If it is the flywheel is there anyone in the area that could walk me through it. I assume i have to DROP the Tranny ARRRRG .... never done it before ... i will pay and buy the beer /forums/images/graemlins/1zhelp.gif
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Starter could need to be shimmed on one side or the other, around the mounting bolt area. Some starter's need a small amount of shim to get the proper backlash, other's do not. Never had to do it myself, but there are many here who have.Chilton's/Haynes manual discuss the topic relatively well, if I remember correctly.
    John
  3. madmike
    madmike 1/2 ton status
    Jan 23, 2002
    496
    ohio
    It could be the flywheel teeth are bad, thus chewing up the new starter gear, and you're right, you would have to pull the tranny or engine out to fix the flywheel.
    Another problem (and cheaper) is that the starter may need shimmed away from the flywheel. I know AutoZone sells starter shim kits that usually come with an 1/8th steel rod and varying shim thicknesses. Just follow the directions in the shim kit, its easy.
    You may have already damaged the teeth on the flywheel though. /forums/images/graemlins/frown.gif Does the engine make weird grinding noises when ya turn it over? /forums/images/graemlins/crazy.gif
  4. flynhi
    Jan 29, 2003
    24
    Tracy, CA
    It did not at first ... but the noise got progressivly worse now starter just spins without engauging the flywheel. but both times i installed new starters the sounded great for about a week the went to S*&%t
  5. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I would say that you need a new flywheel and starter. I went thru the same pain in the arse a few months ago, mine was acting just like you described, I ended up having to put on a new flywheel (flexplate) and another starter. I just took everything loose and slid the tranny back a few inches so I could get a wrench to the bolts on the flexplate. It made it alot easier than having to completely drop the tranny/t-case. I didn't even have to take out the driveshafts. I haven't had any more problems with it.
  6. Langosta39
    Langosta39 1/2 ton status
    Nov 8, 2002
    156
    Moscow, Idaho
    pull off the inspection plate and the starter and look at your flywheel. My starter needed A LOT of shimming down, like 5/32nds, yes, more than 1/8" so my starter was hitting the front of the flywheel and ruining the starter but not the rinbggear...very much. I got a new starter cuz it was toast in 1 month. In the end I had to take the solenoid off the new starter and keep trying differnt shims and manually pushing the starter gear in until fully engaged with minimum pressure. After I got that I hooked everything up and started it 20 times then pulled the starter off to inspect the wear pattern and noticed slight the marks in the valleys of the starter gear so I shimmed it another 1/32 which is the min spacing. The starter install instructions tell you how to do all of this, and so does your NAPA guy.
    All in all, this 1 hr of work goes a LONG way to save you time and money. But it sounds like you need to get a new ring gear first, then do this.
    andy
  7. flynhi
    Jan 29, 2003
    24
    Tracy, CA
    Also have heard of 2 types of starters a " Long " and a " short "does this ring anyones bell .....
  8. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    Where are you getting these starters from? I went through this issue when I first started out. I must have went through 5 or 6 Pep Boy's starters until I was taught the value of a AC Delco starter. Installed that one over 4 years ago now and haven't had trouble since.
  9. Langosta39
    Nov 8, 2002
    156
    Moscow, Idaho
    not on a chevy that ive messed with
    andy
  10. flynhi
    Jan 29, 2003
    24
    Tracy, CA
    they both have come from Napa I have a feeling ... I am getting farked Question though ... if flywheel gears were rounded wouldnt it make the noise from the get go?????
  11. Waxer
    1,857
    Long Beach, CA.
    You can easily see the flywheel (if manual), flexplate (if auto) teeth to see what their condition is. My bet is you're getting cheap remanufactured starters from Napa.
    Do you have the support arm on the back of the starter that bolts up to the side of the block? That is essential in controlling starter movement due to torque. That can cause the starter to move, and the teeth no longer engage right and make the loud noise you hear.
  12. Moose
    Moose 1/2 ton status
    1,062
    Glendale, Arizona
    Waxer I am having the same problem what does this arm look like? I have taken all the shims out and it still is to far away the teeth barley make contact. /forums/images/graemlins/usaflag.gif
  13. Anteak
    Anteak 1/2 ton status
    Nov 7, 2001
    105
    Hemet, Ca.
    Could be electrical. Bad/old cable to the solenoid. Is there oil leaking down on the solenoid? The sound could be the starter spinning and the soleniod isn't fully engaging the stater gear to the flywheel gear. Someone would have to watch it as you engage the starter. Are the gears on the flywheel chewed up across the full face of the gear or only half way.
    Just something else to think about. Are you getting a new soleniod when you replaced the starters. If not, bench test them before you install it to verify that the gear is extending fully.
  14. Waxer
    1,857
    Long Beach, CA.
    Moose,
    I don't have my Hayne's manual with me (which has a pic of it), but hopefully someone reading this will, and can put it up for you. The best way I can describe it is it looks like a molded piece of angle iron. One end bolts up to the side of the block, the other end bolts up to the back of the starter.
  15. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    one way to change the flexplate w/out dropping the tranny is to take out the bottom 2 bolts on the bell housing and replace them with 6" grade 8 bolts. then remove the rest of the bolts and linkage, then you can just slide the tranny back on the 2 bottom bolts and not worry about it falling. just tighten the 6" bolts finger tight.
  16. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Exactly, works perfect. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  17. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Like Waxer said, I too had a lot of starter troubles until I went with an actual AC/Delco starter. That was in 1998 and not a lick of trouble since. I smoked (literally) two starters in six months before that.
  18. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I read some of the replies but not all of them. the problem GM had was i think they had 3 foundries producing the blocks and there is up to a 1/2" varience in them. up til 87 when they went to the one piece seal they then went to one foundry. so the thing to do is to properly match the teeth of your flywheel or flex plate to the starter teeth. if they don't mesh then either space it away from the block to gain room or you may have to mill the nose cone of the starter to get it to match.
