Chiltons sux butt, i need a HAYNES schematic or procedure for my Burb
Discussion in 'The Garage' started by uglychevyZZ4, Dec 30, 2002.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    My 87 TBI Burb's oil pressure guage has stopped and i need a procedure for determining which one is kapoot, sender or guage.
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Is the guage all the way to the max or the min? Unhook the sender, the guage should go to max. Ground the wire the and guage should go to min. Its most likely the sender I go through one every few years.
  3. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    the guage just stopped at 15lbs, then when i moved it to 0 and restarted the truck it stayed there.
  4. prerunner1982
    prerunner1982 1/2 ton status
    Nov 4, 2002
    235
    Oklahoma
    looked through my haynes schematics and could only find a fuel pump oil pressure switch? it has an orange wire and a tan/white wire... hope this helps... if not.. im sorry...
    jon
  5. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Still might be the sender. Unhook it and see what happens.
  6. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    when i removed the guage from the prongs it didnt move, it stays wherever you move the dial too /forums/images/graemlins/tongue.gif
  7. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    odd........ its workin now, but i have my doubts, i think maybe the sender is gettin blocked inlet /forums/images/graemlins/wink.gif
  8. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    If the gauge is working inter. I don't think its bad I would say your sender,or wiring is bad. But it is really easy to test, make sure the wire is getting batt. power with the key on, then with someone watching the gauge ground the wire, the gauge should move.
    DO NOT leave the wire grounded for more than a 10th of a sec. though as you will fry the gauge. I usually just tap it like once or twice and the gauge will jump for the dude in the seat watchin' /forums/images/graemlins/thumb.gif
  9. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    i dont even go that far, i have a meter that will allow me to slowly raise the level of resistance /forums/images/graemlins/wink.gif
  10. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    I'm not sure you read me captain.
    All you need is a jumper wire. /forums/images/graemlins/thumb.gif
  11. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I'm pretty sure the fuel gauge wire is Brown in color..
    ....but you probally have it all figured out. /forums/images/graemlins/thumb.gif
  12. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    according to my book, yes, its tan -ish /forums/images/graemlins/thumb.gif
    aaron, huh? /forums/images/graemlins/laugh.gif what'd i miss.
