Chip off the old computer???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by evilandangry, Jan 13, 2003.
  1. evilandangry
    evilandangry 1/2 ton status
    Dec 29, 2002
    105
    Norwood, NJ
    I have been considering swaping the chip in my computer. I have added a hi flow cat with 3 inch exaust and a k&n filter and feel that the power band could be tweeked a bit. I am new to this sight but I did do a search and found very little info. Please dont tell me that computer chips are like chrome shocks for your engine!! /forums/images/graemlins/eek.gif
  2. dyeager535
    26,980
    Ok, *I* won't tell you. /forums/images/graemlins/smile.gif
    There was a post not too long ago on chips, but seriously, the reality is, to get the most performance, the chips need fine tuned to every single application for best performance in all aspects. The hypertechs and what not usually increase timing, (and the one review I saw was only higher in the RPM band) in some cases so much you need higher octane gas, yet don't deliver performance.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    If that is all you did, just drive it for an hour in different conditions of load, no load climbs decents and the computer would recalibrate to optimize.
    If you change cam or heads and you want real calibration, customefis.com is the place to check, the guy will optimize it for you, he will lend you a laptop and you will plug it in and together you will get it done then he will burn a permanent chip for you. But it's not worth it with only exhaust and filter change.
  4. BigRed89
    BigRed89 1/2 ton status
    Oct 28, 2002
    223
    Los Angeles, CA
    I agree with IceMan. With the minimal mods you have made, you really don't need a computer chip yet. If you really feel the need to get one, I recommend staying away from JET Performance primarily because of cost. I purchased a JET Performance custom chip for my Suburban, only to have it go out after seven months of use. Once the problem was diagnosed as being the chip, one call to JET and they had another custom chip ready for me in two days. They did back up their product, but it was an expensive purchase at the beginning.
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    These are the best pre programed chips I have found:
    fastchip.com
    They work all thru the rpm band. Most other brands only really work at WOT.
    If you want a good performance boost use their stage 2 chip.
    But you will have to put in a 160 degree thermostat and only be able to run preimium gas. Probabally loose some gas milage too.
    Their stage 1 chip works ok it will give a noticable jump throttle responce make your 0-60 time maby a little better, And give a little more power at mid RPM range. It didn.t hurt my gas milage either.
    They also burn custom chips to. But for your needs the stage 1 should be fine.
    As said in posts above chips dont give that big of a performance boost. But will help a little if you have or are going to do some bolt on performance mods.
    But the 150 bucks it would be better spent modifying your TBI to work/flow better you can really pull quite a bit of power out of them with a few simple cheap mods.
    Check out:
    turbocity.com
    They also sell and burn their own performance chips that work well with their TBI mods.
