Chiped pinion gear
Discussion in 'The Garage' started by mrbill, Oct 19, 2004.
  1. mrbill
    mrbill 1/2 ton status
    Jul 1, 2003
    170
    Sugar City, Idaho
    I just bought a used 3.73 setup. Seems UPS was a bit ruff on it and the Pinion gear got lose. The out side tip of a few of the teeth were chipped, some quite abit. Just the tip and not to the face / wear surface. Is this going to be OK?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It'll be fine. You could grind that area off without hurting anything. Make sure any edges are smoothed over so they don't cut into the ring gear.
    I ground five teeth of my DD's ring and pinion just so I could put my lockright in.
  3. mrbill
    Jul 1, 2003
    170
    Sugar City, Idaho
    thanks
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That is, assuming the chipped area is not in the contact pattern.
    There is a tech article at www.ring-pinion.com about this.
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    What Tim said. But, hmm, wonder how they did that. Its not like its easy to chip. Sure it wasnt chipped before UPS?
  6. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    make UPS pay for it, then put it in, then you have xtrr cash
  7. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i sold him the gears, i had an employee package them, apparently he didnt do a very good job. i hope they're still ok. they were in perfect shape before they went into the box.
  8. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    if they were insured... get the insurance $$$
  9. mrbill
    Jul 1, 2003
    170
    Sugar City, Idaho
    I'm happy with the deal!! - Jonny-K5 has been very helpfull. The pinion got lose in the box and bounced a bit. Sounds like the chips won't cause any problem being out on the tips and not on the wear area.
  10. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    they were insured, 100$ each box. if you can get it that would be cool.
  11. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Actually the outer corners of gear teeth are pretty easy to chip. At work on Monday, I put a gear from the transmission I was rebuilding down on my bench (1/4" steel top). It slipped out of my fingers and fell approximately one inch to the tabletop, and 2 teeth chipped.
