chipped gears
Discussion in 'The Garage' started by KGsK5, Oct 3, 2006.
  1. KGsK5
    KGsK5 1/2 ton status
    Aug 26, 2006
    343
    Havre de Grace, Maryland
    i want to rebuild my d44 and 14b before i swap them under my truck. havent had much thime but i did pull the diff cover... this is what i found. would it be ok swap in axle with the ring with those chips? the 2 in the pic are the only ones.
  2. KGsK5
    Aug 26, 2006
    343
    also, how can i find out what gears are in these?
  3. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    I would'nt run it ,they look like some rather large chips.They would probably end up getting worse.Count the ring gear teeth then the pinion teeth and divide that'll be your ratio.45-11 should be 4.10
  4. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    no way are you gonna be able to use those gears and expect them to last at all, I would be surprised if you would be able to back out of the driveway. :screwy: Time for a new ring and pinion, hope you needed a new gear ratio. :D
  5. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    4.09's, pretty bad teeth though. Run 'em till they blow, then replace them.
  6. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    fixed it for ya. anything worth doing is worth doing right.
  7. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    I agree. And 44's aren't worth doing, and aren't worth doing right. All he needs is an excuse to get a 60.:D Even if he keeps the 44, carriers are a dime a dozen if you're resourceful, and I don't see the housings getting taken out by the gears that often. One things for sure, his current gears aren't trustworthy.
  8. 84blazend
    84blazend Registered Member
    Jan 2, 2006
    40
    North Dakota
    If you are going to beat on the truck at all, those gears are not going to last.
    I assume from your post that the axles are not in the truck yet. If that is the case, it is easier to go through an axle with them off of the truck.
  9. KGsK5
    Aug 26, 2006
    343
    its still not on the truck... they are rather rusted so im going to pull them all apart and sandblast the entire outside. then replace brakes and now i guess the gearing. what do you guys think about 4.56 gears with a 6.2/700r?
  10. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    depends on tire size. what size are lookin to run? id say youd need at least 35/36s for 456
  11. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Well in a dana 44, 4.56's make the pinion pretty dang small. I think that'd just be asking for it in a full size.
  12. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    6.2L diesel + Th 700r4:
    4.10 gears with 33" tires
    4.56 gears with 37" tires
    Remember the sweet spot for the 6.2 is 1800 to 2200 rpms.
    Use THIS to check any combos.
  13. KGsK5
    Aug 26, 2006
    343
    thanks for the help guys. and i am going for 36" tires... after i get my 6" lift. oh and i would LOVe a 60... but i can barely afford the lift and tires... the 44 came wiht the truck so imma go ahead and just swap it in.
  14. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ive got 5.13s and im swappin in the 6.2 with overdrive and 39.5's (38.5" true) i think my rpms are gona be a lil high, but thats a good excuse for 42's :)
    in your case id go with 4.56 so that if you want to go bigger later you can
  15. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the gears in my front 10 bolt looked like that, but instead was every tooth. it lasted almost 4 months from the time i noticed it. i was just rutienly changing the fluid. as far as i could tell it has been like that ever since i put the axles in, which was may/june 05. who knows how long it was like that before i bought them. thats not the part that actually completely killed them either, it was the pinion bearings that were destroyed by an unballanced/not perfectly straight driveshaft that ended up chewing the gears completely up.
    my point is that they will last alot longer that you would think. i figured i would break them on the trip i was going on the day after i noticed it.
    that said, if the axle is out, i would replace them before using it.
  16. trollporter
    trollporter 1/2 ton status
    Feb 29, 2004
    518
    Lady's Island, SC
    Exactly what I was thinking! I've got 2 teeth in my front D60 that look just like that and I'm beating the piss out of them. But keep in mind this is a trail only vehicle that never sees pavement.
    highjack: What do you think would cause that? My pinion gear looks good and it's only 2 teeth that are one tooth apart.
    troy
  17. KGsK5
    Aug 26, 2006
    343
    im not in any big hurry to throw these axles in... gotta wait for the money for more lift and new 8 lug rims and 36" tires... so while i got em on the ground im gunna go ahead and put in new 4.56 gears. ill just keep beatin the piss outa those 10 bolts :D
