chipped input shaft tooth question
Discussion in 'The Garage' started by IIVIIoonshiner, Oct 18, 2006.
  1. IIVIIoonshiner
    IIVIIoonshiner Registered Member
    Aug 28, 2006
    40
    Aiken, South Carolina
    I called ORD and had them send me a used but "in good shape for a rebuild" 10-spline input shaft... mine was rounded off on the shift teeth and the 10-splines as well.... the one they sent me looks almost brand new in those areas but the bigger teeth that ride on the idler gear have one tooth that is barely shipped.. (my original was perfect) the one tooth is 2/3rds complete with the other third only missing maybe a millimeter or two where it chipped. Is this acceptable? when i put the idler next to it and mesh the gears they seem to lock and fit nicely. BUt this is my first np205 rebuild... ORD did send it to me though... so I assume if they okay it it's probably fine... I need re-assurance!
    thanks guys
  2. IIVIIoonshiner
    Aug 28, 2006
    40
    if you need pics Ill have to get em tomorrow
  3. IIVIIoonshiner
    Aug 28, 2006
    40
    come on yall! no input? these teeth are huge but how much contact overlap is there? is a small chip like the one i have gonna affect the strength or would it be miniscule? someone has to have an opinion about a gm np205 transfer case!!!!
