chirp chirp chirp (make it stop!!!!)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by megaz, Jun 30, 2003.
  1. megaz
    megaz Newbie
    Mar 13, 2003
    4
    i have a kinda whistle comming from my distributor cap
    what should look for and what is it????????
    /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
    thanks
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    A bunch of twigs in the form of a nest and look for some birds /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  3. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    Vacuum leak at the vac advance? Cap not installed quite right?
    Rene
  4. JustHorsinArownd
    JustHorsinArownd Registered Member
    Mar 20, 2003
    77
    Flagstaff, Az.
    I'm gonna go with Rene on this one. Sounds to me like a vacuum advance leak. I've never heard a rubber hose chirp (could happen I spose though) so I'd check the vacuum advance canister thingy itself. Maybe pinhole?? Or maybe the lever itself is squeaking?? Try unplugging and replugging in the hose and see what you can see and or hear. Good luck!!
    Allan
  5. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    make sure you take your shotgun with you, too. /forums/images/graemlins/laugh.gif
    on the serious side, it could be that the dist is position incorrectly. the rotor could be touching the cap if it's offset a bit. also, try and dip your finger in oil and just wipe all the moving parts with it. just don't use too much.
    worse case, a bad shaft /forums/images/graemlins/eek.gif
    ARQ.
  6. megaz
    megaz Newbie
    Mar 13, 2003
    4
    well ....killed the birds last week so it cant be that.
    i sprayed the guts with a little wd 40 and made shure it was on correctly and checked the vac tube...it does not matter if the line is on or off it still whistles.
    im leaning twards a bad shaft...it started running a little off(like it is hitting a little harder on one piston) about 2 days before the whistle started.
    when i sprayed the wd 40 in it i changed the way it sounded for a little while...then it went back to a steady whistle....only does it when its warmed up though.
    its not realy missing when it runs and it does not matter where i set the cap....it still has that slight vibration to the engine......(more than normal...lol)
    is there a bearing in that thing or will i need to replace the whole shaft????thats one thing i have never had a problim with so i havent a clue..... /forums/images/graemlins/1zhelp.gif
    thanks for the help so far....... /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif
