Choke adjustment question
Discussion in 'The Garage' started by Muddytazz, Sep 18, 2002.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
  2. Grim-Reaper
    7,385
    Atlanta
    Ya have to bend the rod. I fixed my choke like that REAL good. It is now laying in the trash can. I put a little newer Hot air carb on and then converted to electric choke....works so sweet! THis carb doesn't have the teeth on the high idle cam and it just idles it's self down. /forums/images/icons/grin.gif
    Anyway back to your problem. It might not be a bad idea to replace the choke spring. As old as that is it may not have the movement it use to and be part of your problem.
  3. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Thanks Grimmy, I bought a rebuild kit today and going to do this weekend, so back to the parts store i go LOL.
  4. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    I saw a post that you responded to a while back that gave a part number for the choke spring. I couldn't find the post when I searched and was wondering if you might know where I could get a new choke spring for my 83 quadrajet carb.
  5. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    OK just looked at the picture at the top of the post. I might need to clarify. I have the electric choke and need to replace my coil thingy(technical terms) inside the electric choke. It's sticking the choke shut and isn't releasing the fast idle. I usually have to trip it by hand but of course as soon as I hit the gas it's stuck on fast idle again. I've got 12 volts going to the choke. I'm trying to decide if I want to fix the electric choke again or go to a manual one.
