choke light always on.....suggestions?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jackedjimmy350, Oct 23, 2002.
  1. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    /forums/images/graemlins/1zhelp.gif
  2. 85 blazer
    85 blazer 1/2 ton status
    Feb 12, 2002
    118
    Avoca NY
    PULL THE BULB LOL LOL /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
  3. dyeager535
    26,979
    problem with the oil pressure switch perhaps...don't think there is anything else that will cause this, besides bad choke wiring or a bad choke. (and those are guesses too, never spent time on electric chokes, just know they use an oil pressure switch)
  4. jackedjimmy350
    Oct 20, 2000
    3,141
    ok heres a couple more interesting tid-bits of info..it seems to idle a bit high after i put it in park before i get ready to shut her off (same as when i start it up in the mornin)...kinda jumps a little when you put it park or reverse. the other thingis i just had new autometer gauges put in, and the new oil pressure gauge seems to work more like a tach if you know what i mean. anymore ideas????
    thanks for the /forums/images/graemlins/1zhelp.gif
  5. trouble1
    trouble1 1/2 ton status
    Sep 28, 2002
    346
    travelling, probably lost
    I'm guessing you had an electric oil gauge put in...I had the same deal happen when I switched my gauges installed. Heard the same problem from several others. I yanked mine out and went to a mechanical guage, in my opinion it does purrfect.Choke Light....Cant help you, I removed that bulb a long time ago.....Then again, untill last week, I dont think my electric choke was ever hooked up. /forums/images/graemlins/eek.gif /forums/images/graemlins/k5.gif
  6. jackedjimmy350
    Oct 20, 2000
    3,141
    yep, electric gauge. ill have to go back to the shop and see what they say they can do about it. is the choke really necessary, lol? /forums/images/graemlins/wink.gif
  7. jackedjimmy350
    Oct 20, 2000
    3,141
    btt /forums/images/graemlins/1zhelp.gif
  8. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    cured my choke light by swapping the fuel filter, and hosing the crap out of my carb externals with carb cleaner....also check that the three screws on your choke are atleast tight...it not hard to adjust the choke did mine myself last week!
  9. eshorvath
    eshorvath 1/2 ton status
    Jun 20, 2002
    373
    Southern Oregon
    Mine did the SAME THING>.
    Make sure the wire on the choke switch, behind the Distributer, is connected GOOD, and that it is not broken. If that wire is broken, loose, or off, it will cause this problem.
    Ed
  10. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    Sorry to drop in on this thread but what was the process for adjusting the choke? Mine is actually rivetted.
  11. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    You probably already checked but I had the same problem and it was just the fuse. /forums/images/graemlins/crazy.gif
    Just my two cents since I busted in on your thread! /forums/images/graemlins/rotfl.gif
  12. jackedjimmy350
    Oct 20, 2000
    3,141
    its cool dude, any and all info is accepted and much appreciated! /forums/images/graemlins/thumb.gif
  13. jackedjimmy350
    Oct 20, 2000
    3,141
    but if the wire is disconnected, wouldnt the light not come on?
