choke light
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wnderbra, May 8, 2000.
  1. wnderbra
    wnderbra Registered Member
    Feb 18, 2000
    47
    Virginia
    I have an 83 k5 with a new 350,holley intake and carb with electric choke . Everything has been runnin fine but two days ago the choke light on the dash came on .This light has never lit up in the three years i have owned it. It does'nt appear to affect the choke it still knocks down to the same idle speed. Can someone school me on the original function of this dash light and a possible reason why its on now. The temp here in va. has gotten alot hotter the last few days other than that everything is set the same as it was when the motor was installed about a month ago. thanks
  2. Blazerbob
    Blazerbob 1/2 ton status
    214
    Western NY
    I have an 83 also and once the choke light came on when all the oil leaked out on the way to the beach. It may be wired to come on when the engine gets hot also. Do you have a working temp guage? Just a thought.
    <font color=blue>Blazerbob</font color=blue>[​IMG]
  3. jakentn 83k5
    jakentn 83k5 Registered Member
    26
    east Tennessee
    I too have an 83k5..when i bought it the choke wasn't hooked up...I hooked it up & the light came on..checked wire with meter & wasn't getting full 12volts..not sure if was due to age or what, but it would not open my flapper...ran another hot wire from switched 12v & worked good..
  4. 6.2 man
    6.2 man 1/2 ton status
    636
    Curtis , WA
    If I remember right the choke and oil are wired in together so it might indicate a problem .
  5. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    I had a problem with the choke sticking so I took the cleaner off and the light started coming on intermittently, so I replaced the cleaner and it went back out, There is something in the owners Manual about the choke light, I just don't recall excatly what it says...
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
