Choke problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bajaviking, Oct 24, 2002.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    Sometimes it takes a long time before my choke disconnects, even if I hit the throttle several times it stays accelerated. Even when it is warm this happens. I have a q-jet with electric choke, anybody know how to fix or adjust this. /forums/images/graemlins/confused.gif
  2. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    You might wanna check your throttle return spring. I had the same problem and it was only the return spring.
  3. bajaviking
    Apr 10, 2002
    752
    Baja
    Thanks, I will look at it tonight.
  4. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Let us know what you find out. I'm curious to see if you had the same problem as me. Two or three mechanics couldn't figure out what my problem was and it wasn't until posting a message on this board that I found out that it could be something /forums/images/graemlins/thumb.gif as simple as the throttle return spring. Good luck!
