Choke Qusetion
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stylzz, Sep 20, 2002.
  1. Stylzz
    Stylzz Registered Member
    Sep 9, 2002
    95
    Mystic, CT
    Let me start by saying how great this site is. I have been checking it out for a couple weeks now and have learned more about my truck than I ever knew. Heres the problem, until a few weeks ago when I would start my truck I would let it warm up for about 30 seconds then I would kick it down with no problem. Now it wont kick down, it will take a few minutes until I can get it to kick down. I removed my stove pipe around this time because it was ready to fall out. Could this be the problem? or do I need to adjust the Choke? And how would I do that? I already checked other posts about this issue but I'm still not clear about the whole thing. 1980 K5/Q-Jet. Any help would be greatly appreciated.
    Joe
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    When you removed the "stovepipe", you took away the tool that the engine uses to warm itself up. When your engine is cold, the valve in your aircleaner closes off, forcing the engine to breathe from your exhaust(warm air). Once the sensor in your aircleaner detects a set temp, vacuum is sent to the valve and it opens, allowing the engine to breathe fresh(cool) air.
    I'm not a carb guru, but is your choke electric or heat-activated? If it's heat activated, removing the stovepipe might cause your choke/high idle to stay engaged longer.
  3. beefjerky
    beefjerky Registered Member
    Feb 14, 2001
    64
    how can you tell if the choke is heat activated or electric?
  4. Stylzz
    Sep 9, 2002
    95
    Mystic, CT
    I'm pretty sure the choke is heat activated because if it was electric I would hear that clicking sound when I turn the key on right? Also, I always had to kick it down manually. I'm going to rig some kind of stove pipe up and see if it helps. Thanks for the info.
    Joe
