Choke RPMs to high when cold???
Discussion in 'The Garage' started by GM Man, May 7, 2003.
  1. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    When I fire up my Jimmy in the morning the choke starts the RPMs off at 1300. After a minute it jumps up to 1500 RPMs. Is this ok for a SBC when its cold? The carb is a Edelbrock 1406.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Mine on my Qjet usually runs about 1000-1100 startup and climbs up to around 1300-1400 as it warms up.
  3. Grim-Reaper
    7,385
    Atlanta
    Take the air cleaner off. Standing infront of the truck . Looking at the carb on the left side is the choke. Up against the body of the carb is the high idle cam and a stop screw. counter clockwise will lower you RPM at high idle it doesn't take much adjustment. 1/8 of a turn may be plenty. I usualy adjust it down to about 950-1000 when warmed before tapping the throttle to drop the choke.
  4. GM Man
    Jan 12, 2003
    549
    Denver CO
    Cool, thanks guys for your inputs. I'll drop the RPMs.
