Choke Setups?
Discussion in 'The Garage' started by Confedneck, Nov 26, 2003.
  1. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    ok...thinking about swapping to a q-jet on my truck and ditching the holley shitbarrel carb...how hard is it to setup or install a manual choke onto a q-jet??
  2. Confedneck
    Nov 1, 2002
    5,236
    anyone??? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/confused.gif
  3. ben427
    ben427 1/2 ton status
    Mar 10, 2002
    1,123
    Waverley, Nova Scotia
    Easy as pie. Most auto parts stores sell kits for less than 10 bucks. Takes about 30 mins to install. I had on on my 72,it was the best thing i did to it.
  4. Confedneck
    Nov 1, 2002
    5,236
    is it as simple as removing the old choke off the carb and installing this setup? i cant imagine it being that difficult, are the kits carb specific??
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    electric choke are great and easy to convert to if already dont have it, also the hot air vacuum chokes were good too as long as you left them alone
  6. Confedneck
    Nov 1, 2002
    5,236
    i kinda like the idea of a manual choke because it seems simpler with less parts to break/malfunction..my intake has a blockoff plate bolted to the choke feed area and the intake is going to the dumpster once i can afford a performer air gap...
  7. ben427
    Mar 10, 2002
    1,123
    yeah pretty much, you just take the cover off and remove the guts. a little lever is supplied in the kit that will move the choke, and a rod sticks out through a supplied cover which the cable goes on too. The screws holding the choke cover on were my only trouble, but the came right out with vice grips. The kits are pretty much generic. Mine had two different covers and levers for different carbs.
  8. Confedneck
    Nov 1, 2002
    5,236
    thanks for all the help guys!!
