Choke to vacume??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lew, Apr 29, 2000.
  1. lew
    lew Registered Member
    Mar 12, 2000
    39
    reno,nv
    Hello,
    Well this is the most stupid question I have ever asked, I think!!!!!
    My 86 Blazer has the comp Rochester, stock but has a hard time starting when cold. I noticed that the line coming from the chock has been pluged off. Had the truck for a while but just noticed this.
    Do i just run this hose to a vacume hole on the manifold or one on the carb.
    Thanks for the help.
  2. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    There should be a sticker under the hood that shows where all the hoses go, if not ask and I will scan the one I have from the manual and post it for you.
    <font color=green>[​IMG]Eagle86K5[​IMG]
  3. lew
    Mar 12, 2000
    39
    reno,nv
    Eagle,
    Thanks for the reply. There is no sticker under the hood, previous owner must have peeled. I would really appreciate the scan. If any one can tell me where to just hook it up that would be great too.
    Thanks.
  4. Eagle86K5
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Not a problem I will scan it tomorrow....I need to know everything you can tell me about the motor to get you the right diagram. Do you have EGR, air pump,engine size,year...ect.
  5. lew
    Mar 12, 2000
    39
    reno,nv
    Eagle,
    here are the specs.
    1986 K5
    350 C.I.
    EGR mounted but not hooked up either.
    Emissions stuff taken off
    No smog pump.
    Stock manifold
    stock exhust maifold
    Air conditioned
    Do not have emissions in my county. YET!!!
    Thanks again.
    P.s. Do you know what size special socket to use on the front hub of this 86 k5 so i can get to the bearings?
  6. Jamie
    Jamie Registered Member
    47
    Johnstown PA.
    Your Blazer should have come with an electric choke. It sounds like you have an older carb with a hot air choke. You can go to Autozone and buy the electric choke insert for about $25.00. Any more questions give me a holler.
  7. Eagle86K5
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Lew,
    I searched through all 57 vac hose diagrams for an 86 Blazer and none of them show what you have, the other gentleman is correct. They came with an electric choke, and it is possible to but it as an add on...sorry I cannot help you more...
  8. SNOHEAD
    SNOHEAD Registered Member
    May 8, 2000
    12
    MT,WEST YELLOWSTONE , GALLITAN
    CAN ANYONE GET ME A VACUAM DIAGRAM FOR AN 82 4X4 BLAZER 350
  9. Eagle86K5
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Here is the best I can do for you...the Chiltons manual is not very explicit in the diagrams until 84 , then they have about 20. Hope this helps...
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  10. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Ray,
    Do you have the chiltons manual for the blazers? If so, I was going to order one but was wondering why it only goes to the year '82? I have a '84, is there much difference b/w them?
    <font color=green>Money</font color=green>--&gt;Blazer
  11. Eagle86K5
    Mar 5, 2000
    974
    Whitehouse, Ohio
    My manual is #(8577) 28622 Full Size Trucks 1980-87 Covers all U.S. and Canada Chev/Gmc 1/2, 3/4 and 1 ton P.U's, Blazer, Jimmy and.......Subs, 2 and 4 wheel, gas and diesel.
    Cost...$14.95
    2B1ASK1
  12. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    Thanks, I will be ordering one shortly.
  13. SNOHEAD
    May 8, 2000
    12
    DO YOU THINK U COULD PLEASE SEND ME THE IMAGE A LITTLE BIT CLEARER
  14. Eagle86K5
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Here is another try...
    2B1ASK1
