Choosing A Flexplate
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Resurrection_Joe, Jan 27, 2002.
  1. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I'm almost 100% sure that I need a new flexplate, and am going to try and get it on myself. I'm just wondering which brand I should go with. I have a 78' 355 mostly stock. What's the tooth count I need? Thanks a lot!
    1978 K20 - 355ci, np205, th400, D44, 14F, 7" of Lift, 36 x 14.5 TSL Radial
  2. konajoe
    konajoe 1/2 ton status Premium Member
    Nov 15, 2000
    112
    7
    Massachusetts, U.S.A.
    RJ,
    Check your starter…
    GM starters use
    153 tooth 12 ¾” flywheels straight across bolt pattern
    168 tooth 14” flywheels offset bolt pattern
    Hope this helps, [​IMG]
    Joe
    79K10
  3. dyeager535
    26,977
    Never heard of a 14" flywheel. You sure you didn't mean 10.4 and 12"? (probably not exactly 12" either, but thats all I've ever heard) You are corect though tooth count/diameter governs the starter nose/block mounts you use.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
