Choosing the right CFM for your engine
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Paxx, Jan 22, 2004.
  1. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    How do you determine what the proper cfm carb is for your truck. I used to think that the higher the # the better but I'm starting to think that depending on your application bigger isn't always better.
    How do you know? Is my 750cfm too big for my 355?
    I crave all your free knowledge /forums/images/graemlins/deal.gif /forums/images/graemlins/tongue.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    750cfm, 355 won't have good throttle response. I have a 650 on my 355, if they made a Thunder AVS Off Road 600 I would have gotten that.
  3. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    there is some formula for figuring this out, the higher your engine needs to rev and the more hp it makes the bigger carb you need. i think a 350 that redlines at 5K with 300hp should have a 600cfm. you need to be making like 450+hp and spin to 6000+rpm to accually need a 750cfm.
    if i find the formula ill post.
  4. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    CID x maximum RPM
    3456
  5. Jonny-K5
    May 27, 2003
    1,654
    SoCal
    thats it , dang your quick /forums/images/graemlins/thumb.gif
  6. J.R.
    J.R. Guest
    check out this months chevy high performance magazine. there are many factors involved, what works on one 355 may not be the right one on a different 355. cam, compression,intake all are a factor in finding the right carb. for a mild 355 on pump gas with no nitrus a 600-650 cfm vac. carb will do. the easy way to find out is to call a carb or parts company and ask them. give the specs on your motor and they will tell you. good luck, hope this helps..
  7. dyeager535
    26,982
    191
    yep, saw an article awhile back about carb selection, and the 350 they were testing made the best power with a 1000CFM carb, which by conventional wisdom was way too much.
    But with all the variables, your optimal will vary. 750CFM Q-jets were used on 6 cylinders, 800CFM's on 305's and 307's, so that may give you an idea of how mcuh engine variables and application play.
  8. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I ran a 600cfm on a built 355 in a 72 Nova. No problem at all with 600 CFM for a small block in my opinion.
  10. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Here is the formula:
    RPM for max power = Z
    Cubic Inch Displacement = Y
    Volumtric Efficiency = X (stock heads .80, better heads .85, performance .90)
    X((ZY)/3456) = W
    W((1.5/.5)^.5) = CFM needed
  11. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Carb size depends on what you plan on doing with your motor. An oversized carb will probably hurt you on the low end. An undersized carb will hurt on the top end.Call hollys tech support and talk with them and see what they recommend.
  12. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    Sorry but how can I determine what my redline is? I'm not sure since i have an aftermarket tach that you set your own redline for.
  13. mudjunkie 82
    Dec 27, 2002
    11,449
    Cleveland Ohio
    it all depends how your motor is built. What is the upper R.P.M range of your Cam?
  14. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    Thnx for all the replies so far /forums/images/graemlins/thumb.gif
  15. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    You determine that. Does the motor pull hard to 7000 rpm's?
    Did you put enough money into the rotating assembly?
    Pick the highest your motor will see on a semi regular basis, taking into account the parts used to put it together.
    If you are throttle crazy, lean towards the 'big' side.
    If you like throttle response and don't rev the heck out of it, lean toward the 'smaller' side....
  16. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    lol I've always been too scared to rev it past 6000 cause I thought it might be too high so I don't know if it will go to 7000. I would never rev it that high though. It usually sees no higher than 5-5500 because it starts to lose power after that.
    And I want to do a cam swap in the near future so after that it will likely see no more than around 4500rpm
  17. SUBFAN
    Mar 23, 2003
    2,334
    Davenport, Ia
    I believe in rev limiters too....At times the brain does not care how high that motor is getting pushed, and the wallet is saying hold back /forums/images/graemlins/eek.gif
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I never care, thank God I've got a rev limiter to keep me from being stupid again.
  19. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Make sure your engine gets balanced too or it will surely blow up.
  20. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    here is a quote from the holley site [ QUOTE ]
    Engine Size (CID) X Maximum RPM / 3456 =
    CFM @100% Volumetric Efficiency
    EXAMPLE:
    350 CID X 6000 RPM = 2,100,000 / 3456 = 608 CFM
    Approximately 608 CFM would be required for this engine. However, most street engines are capable of achieving only about 80% VE; a modified street engine with ported heads, headers, good intake and carburetor can achieve about 85% VE; a fully modified race engine can achieve 95% or greater VE. The CFM number arrived at with this formula must be factored by this percentage.
