Choosing Valve Train
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Stoopalini, Jan 4, 2005.
  1. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    So I pulled the sbc350 out of the Blazer on Sunday and dropped it off at a machine shop today. I'm having it bored .30 over and installing 6" connecting rods with new pistons. I'm wondering what cam, lifters, springs, etc.. would be best? I'm looking for good low end torque but still would like to cruise around 5k RPMs.
    Any suggestions?
    Thomas.
  2. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    need some more info to be helpful.... early or late sb... carb tbi or?
    what comp ratio... etc
    cam
  3. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Good points ...... Early model 2-piece rear main, Q-jet carb and aprox 10:1 comp ratio.
    Thomas.
  4. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    5K cruising is quite alot. But for your low end TQ your not going to need anything fancy. Valve springs a step above stock should be fine, for around .480 lift max that you'll probably run. You will also be fine with a hydraulic cam, but might want to consider going roller since your cruise rpm is so high. But with going roller your going to shell out $400 by the time your done.
  5. stevewix
    stevewix Registered Member
    Dec 2, 2004
    83
    aside from the obvious, the aboslute BIGGEST lesson that i learned with valvetrain is that cheaper IS NOT better. buy from a reputable company, spend a few extra dollars to do it right because man it sucks taking it all back apart when the cam goes flat and ruins your $900 crankshaft from all the metal!
  6. bigblock44k5
    Jun 8, 2003
    396
    Hurlburt Field, FL
    As long as the valves are adjusted properly, no cam should go flat unless there are quite a few miles on it.
  7. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Thanks guys.
    The 5k cruising RPM is probably a bit high, let's say a 3k RPM cruise then. I want to be able to cruise at 65mph or so on the highway when making those road trips to the mountains/beach/etc without straining the components.
    I am reusing the stock crank and the stock heads, just replacing the cam, springs, rockers, etc.
    Thomas.
