Chop Saw tube notching exposed!
Discussion in 'Center Of Gravity' started by BadDog, Dec 20, 2004.
  1. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I like many others do most of my notches (tube fish-mouth) using a chop saw, even though I have a "hole saw notcher" and plasma cutter. However, I pretty much guess at how it needs to be cut. Sometimes it works, sometimes I grind a while, sometimes I fill a 1/4+ gap... Recently on PBB there was a thread about how this is done more precisely. The best post was by "tigweld" on PBB and is quoted below. After the quote is a link to the whole thread. I thought this was just too good not to post here (and make it easier for me to keep up with it too!)
    Full thread on PBB.
  2. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    all i can say is wow! i need more experience.
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    That is some baddass information there. Believe it or not, I actually understand that and can't for the life of me think of why I didn't think of notching like that a long time ago instead of just using my angle grinder to make the notch after using the bandsaw to cut the angle :doah:
  4. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    Anyone got any pics of this for the slow kids:confused:
  5. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I must admit that does work rather well. After doing my bed and exo last January with a holesaw notcher I moved into this method of notching and it was much better. I used to get so frustrated with the holesaw notcher that about every 10 notches I would throw it across the garage then go in the house for an hour to calm down... But the chop saw was still slow and required some grinding was loud (I have sensitive ears and loud things bug me and give me headaches). I bought a bandsaw to use for a chop saw since I couldn't stand the noise anymore and havn't had the chop saw out in probably 8 months now. My new notcher:
    Notches from 0-90* in seconds :D ;)
  6. alf4444
    Nov 1, 2002
    2,051
    T-ville, ut.
    tHIS i THINK WOULD BE THE IDEAL SETUP ALTHOUGH MOST OF US DON'T HAVE THE ROOM OR THE FUNDAGE FOR A LATHE:blush:
  7. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    yeah, i was following that thread over there... very usefull info. Interesting that some people who fab a lot and can definitely afford real notchers etc have gotten good enough with the chop saw method that they dont even bother with anything else. Pretty cool since a chop saw can definitely be had cheaper than a good notcher.
    j
  8. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    That lathe method is great unless you are using thin wall tubing with deep notches. The thin wall tends to bend at the tip when you get deep. You have to cut the notch, then file down some of the tip, then cut some more. It works great. I built a jig that pretty much looks exactly like the one shown. I always wondered why you can't buy those to mount up to your tool post.
    -Chris
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Sure, works great; assuming you can afford, have room for, and know how to use a lathe... ;)
  10. nightmare73
    nightmare73 1/2 ton status
    Mar 4, 2005
    169
    Colorado
    Chop saw tube notching
    Nice quote from tigweld. Can't wait to try it out. I'm building a full cage and am new to this type of work.
  11. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    Great info there guys! But that would take all the cursing and getting pissed at the tube, out of the whole cage building experience! :D
  12. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    Back in my Mini-Baja days I could notch tubes like that on the bandsaw faster than anyone else could do it with a hole saw. It's so much easier for small angles too, especially since most notchers only go to 60*.
  13. i8yrsuv
    i8yrsuv 1/2 ton status
    Aug 31, 2003
    327
    Santa Rosa,NOR KAL-IFORNIIA
    Check out " Williams low buck tools" ,they have a notcher that works good and is affordable. Do a search for it !
    [I am not related to the peoples.]
  14. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    All i have ever noched tube with is a home made chop saw my boss made.
    he had been cutting on it for years,(making railings) when a guy tryed to sell him a nocher he said he would buy it IF it was better or faster them him.
    the salesman said he dident need it!
    once you do it for a bit you will have the hang of it and will be fine.
  15. NoRulz
    NoRulz 1/2 ton status
    Feb 6, 2001
    388
    Mesa, AZ
    chicken? :wink1:
  16. Metal Twister
    Metal Twister 1/2 ton status
    Jan 8, 2010
    323
    SoCal Diego
  17. Metal Twister
    Jan 8, 2010
    323
    SoCal Diego
  18. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    holy old thread batman.....
    I chopsaw about 80% of my notches.....
  19. Captainfab
    Captainfab 1/2 ton status Premium Member
    Mar 5, 2006
    468
    Coeur d"Alene,Idaho
