chrome bumper
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Confederate9, Oct 19, 2000.
  1. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    i got stock front bumpers and they arent shiney or anything, but they have like little specs of rust on it. they are tiny dots pin size all over the bumper, is there anything to get this off and then make it shiny.?
    i have heard someone calling it "making it chrome" is that a correct term?
    thanks for the info fellow CK5'ERS
    Confederate's w/ K5's!
    '85 K5: BIG BAD AND MEAN
    "DONT BE PROUD IF IT AINT LOUD!"
  2. EODBRIAN
    EODBRIAN Registered Member
    Feb 19, 2000
    82
    Indiana
    s.o.s. pads and water will probably do the trick. i have this problem on my harley pipes after i get get caught in the rain and this usually takes it off. give it a shot.
    EODBRIAN
  3. arnold88
    arnold88 Registered Member
    May 31, 2000
    19
    Bentonville, AR USA
    If it's the stock chrome bumper, there are 2 good products for "restoring" the shine that I've used. One is made by Turtle Wax, it comes in a green aluminum can, I think it's simply called Chrome Polish. The other is made by Mother's. I used the Mag & Aluminum Polish, it works great. It can be a pain to get off. I suggest that you wipe it off with one cloth, then mist water on it and buff it to a shine with a soft terry cloth. Hope this helps.
    [​IMG] Great works are never finished [​IMG]
  4. BigBurban
    BigBurban 1/2 ton status
    Jun 14, 2000
    237
    AZ
    SOS pad to shine it up and remove the rust. Afterwards, hit it with a coat of wax or two. Probably take 10 minutes at the most and works like a charm.
    <font color=red>~BigBurban</font color=red>
    http://www.geocities.com/crash607
  5. MuleMaster
    MuleMaster 1/2 ton status
    Mar 2, 2000
    147
    Wayne, NJ 0747
    Use any chrome polish you like, but use a toothbrush for applying - works wonders! (Probably You should do that in some hidden place, people mostly laugh out loud seeing a guy working on his truck with a toothbrush [​IMG]).
    CU
    MuleMaster
    <font color=blue>K5 Blazer...because size DOES matter
    http://projectmule.coloradok5.com</font color=blue>
  6. Bigmeats
    Bigmeats 1/2 ton status
    Jul 29, 2000
    523
    Manhattan IL
    steel wool and some wd 40 works great! you can also use a product called never dul im not sure on the spelling. bothe worked well on my bumpers and my motor cycle
    Bigmeats
    Carl...75 Blazer...Manhattan IL
