chrome molding. how do i remove?
Discussion in 'The Garage' started by dodgetruck91, Apr 8, 2004.
  1. dodgetruck91
    dodgetruck91 Registered Member
    Oct 22, 2002
    99
    New Berlin, Wisconsin
    just wondering how i remove the chrome molding towards the bottom of the body so i can paint. I have to reuse it. thanks /forums/images/graemlins/k5.gif
  2. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Just peel it off. There is this bit that fits your drill and works like an eraser to remove the gum part ( http://www.eastwoodco.com/ ). You can buy some adhesive tape to use to restick it or simply buy some new stuff at Pep Girls. It's like $25 a roll and it takes like 2 to do a truck.
  3. gm4x
    gm4x 1/2 ton status
    Apr 6, 2004
    347
    Pendleton, Indiana
    If it's taped on, put some laquer thinner in a squirt bottle & soak behind the moulding (the tape) & let it set abit before removing. It'll help "soften" the adhesive. /forums/images/graemlins/waytogo.gif
  4. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Use a tiger torch and melt 'er off! /forums/images/graemlins/peace.gif
    J/k. I used a razor to get it off, then a paint scraper to get the rest off, but that took a while /forums/images/graemlins/doah.gif
  5. gm4x
    gm4x 1/2 ton status
    Apr 6, 2004
    347
    Pendleton, Indiana
    but NOT after using the laquer thinner!!! /forums/images/graemlins/weld.gif
