chrome tranny pan ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K-Fiver, Jun 22, 2000.
  1. K-Fiver
    K-Fiver Newbie
    Jun 17, 2000
    3
    tampa fl.
    Ijust got a pan for my 350 its 2 qrts. x-tra but its chrome hav'nt installed yet should Itake it back or will it be cooler than the stock one.
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Don't know for sure about that pan but do know that chrome retains heat and doesn't desipate it, so I would assume it would make yoiur tranny run hotter, just a guess............
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
    http://burt4x4.coloradok5.com
  3. slodawg
    slodawg 1/2 ton status
    Apr 30, 2000
    190
    Southern Arkansas
    Ive got a chrome pan on mine it does run a tad bit hotter but i dont haul or pull trailers so it does allright for me.
  4. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    What are you using to measure the temp. ?
  5. Andreas
    Andreas 1/2 ton status
    188
    Sweden
    I´m always told chrome pans leak like h*ll?
    Andreas
    406cui of pure sh*t[​IMG]
  6. dumbfounded
    dumbfounded 1/2 ton status
    May 20, 2000
    176
    Castalia, NC
    Yes, Crome doesn't transfer heat as well as say bare metal, or just plain flat black, but the tranny pan isn't designed to cool crap. It's relatively small. Compare it to your case on the tranny. A little crome on 1/7th the surface on the tranny won't make a difference. Even towing it wouldn't matter. And if you are that worried get a tranny cooler. Keep it and enjoy the added capacity. That's what is going to make it better by adding longevity........
    Wasn't me.............
  7. Scoobydoo
    Scoobydoo 1/2 ton status
    Jun 9, 2000
    244
    Phoenix / Peoria ARIZONA. (75thAve/DeerValley)
    If you can take it back, and get the same thing, but cast aluminum you will be way better off. Aluminum dissipates heat much better[​IMG]. They usually cost a little more.
  8. slodawg
    Apr 30, 2000
    190
    Southern Arkansas
    My chrome pan doesnt leak but Ive got an ancient chinese secret.. Do not put sealent on your gasket!!! Paint it with regular black spray paint let it dry then apply another thick coat and stick it to the pan then bolt it up. Do not over tighten it!!! Thats what causes most pans to leak. As far as chacking my trans temp I've got a gage run inline I got of my buddy's race car. I think you can get them at the parts house.
  9. K-Fiver
    K-Fiver Newbie
    Jun 17, 2000
    3
    tampa fl.
    I'm gonna try yor trick with gasket dawg ,I already got a cooler on it but Iguess the only to make sure is to put a temp. gauge on itthanx
