Chrome trim around headlights
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jarheadk5, Mar 20, 2001.
  1. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I need to remove the chromed metal trim around the headlights. Not the plastic cover, but the metal that surrounds the headlights and grill. How does this come off? I've got some surface rust that I want to clean up behind it.
    [​IMG] Semper Maintenance!
  2. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Ok i take it your talking about the trim that holds the head lite in right? if so there be, (brb) ok i had to look at mine and i have 4 screws that hold the head lite in. hope this helps out Eric
    Lost? i'm not lost i'm just disorienated
  3. jarheadk5
    Mar 6, 2000
    4,389
    PA
    No, I'm talking about the chromed metal trim that surrounds the outside of the grill and headlights. Out at the ends, where it touches the front quarters, is where the rust is, and I can see it extends under this trim, I just can't see how to get the trim off.
  4. jarheadk5
    Mar 6, 2000
    4,389
    PA
    Still looking for help with this...
  5. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    it's either clipped in from the back... or screwed in...
    Um... yes officer I know it's too big...
  6. Dave
    Dave Registered Member
    Apr 23, 2000
    63
    Grafton, Wisconsin
    Take out the grille and headlight bezels. Once those are out, there are a handful of screw holding in the "grille outline moldings".......easy to do.....
    Dave Hiller
    1973 Chevy K-25
    1996 Chevy Caprice x-cop car
  7. WILL
    WILL Registered Member
    Feb 4, 2001
    44
    Indiana
    Thats not true. If you take out the headlight bezel there are 2 nuts on the side. One on top and one on the bottom where the chrome attaches to the middle chrome on top and bottom. Sio there is a total of 4. I know because i just replaced this part. By the way it takes a 7/16 to remove them
    Good Luck
  8. jarheadk5
    Mar 6, 2000
    4,389
    PA
    AHA!! Thank you WILL! Now if only it would stop raining...
